Results 1 to 16 of 16
    Established Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '14 A6 TDI - Previous RS4, 4.2 allroad, A4, A5
    Earth
    Adding Euro Push Button Start??
    Has anyone successfully added the European Push Button Start to a North America Spec RS4??
    OEMPlus has said they can get the parts, but aren't sure about the wiring or VAG-COM Coding. Anyone have some thoughts on it??
    :wavey:
    Feb 13 2004
    2007 Honda Element SC
    Silicon Valley, CA
    Kevin - Moderator, Audizine
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Euro LED Tail Lights, Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, Eurocode Alu Kruez, Hotchkiss F/R Swaybars
    Build thread
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Quote Originally Posted by PB4UGO View Post
    :wavey:
    Yeah I've got a thought. It's unnecessary since you still have to turn the key anyway. Not worth the time, effort or money just to add another step to starting your car.
    But the links above seem to tell you everything you need to know.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    In, Out and Around...
    agreed. complete waste of time and money. much better mods out there for the money.
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    Huge pass. Why add another step to start the car?
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    I have had one or two customers do this to full completion.
    It required quite a list of parts just beyond the switch and I do still have the wiring information handy for purchasers. The conversion is generally useful if you want to go full EU spec on the interior, which is the only reason I'd see it be worth doing, even though it is a nice little trick piece to have.
    If you are genuinely interested I can help, PM or email: [email protected]
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Feb 13 2004
    Silicon Valley, CA
    I would be more interested in proximity start like my brother's Toyota Camry. If I have the key and get close enough, the doors unlock and I can remote start with a button. When I get in, as long as the key is in my pocket, the car continues to run and I can drive away.
    Build thread
    Active Member Two Rings avarfang's Avatar
    Jan 14 2010
    Kansas City, MO
    Quote Originally Posted by Stubek View Post
    x2
    Oct 12 2010
    Earth
    Had that on my 08 A5. It was, I think, one of the best features fitted to an automobile. It was as easy as walking up to the car, open the door, press clutch, push start, drive off. To retro-fit though I think would be horribly cost prohibitive.
    Veteran Member Three Rings dtoys4.2's Avatar
    Oct 01 2007
    Imola%20RS4%20bagged/500whp%20300zxTT/Gated%20V10%20R8
    queens NYC
    still having to turn the key makes it pointless. i had keyless entry and start on my 08 v8 touareg. was the best thing. key never left my pocket. touch the handle and the door unlocks. sit inside step on the brake and hit the button. if it was like that then i would do it in a heartbeat. if not its a total waste
    Dec 05 2006
    So. Cal.
    Question: What happens of you get in the car, put the key in the ignition and turn it as if your starting it? Will the car still start?
    Aug 07 2008
    Dallas, TX
    Depending on how you wire the system you can maintain having the key work to start the car as well as the push button or just the push button.
    Cheers,
    www.europrice.us
    [email protected]
    Dec 05 2006
    So. Cal.
    cool!
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    I did the mod to my b6 s4 way back in the day. skip it unless ur going for a full euro car
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Veteran Member Four Rings Zac's Avatar
    Mar 26 2010
    B8.5 A4, MK6 Golf R, F30 330I, 06 Explorer
    So Cal
    On the Q7's the key just has to be in the car...thats not the case with these? If you have to turn the key anyways then yes..waste of money and time.
    Nov 05 2006
    Fair Lawn
    same with the new s4's. from all that ive read, the actual euro cars you cant turn the key more than the accessory setting meaning you HAVE to go thru the process every time
