Results 1 to 6 of 6
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    REVO settings for fuel economy
    I am planning a road trip from DC to Florida and trying to figure out the best REVO settings for fuel economy on the highway. Any ideas?
    Im thinking
    0 Boost
    5 Timing
    8 Fuel
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Aug 17 2009
    Pittsburgh
    0 boost will do all sorts of strange things to your car as the wga wont be able to contain all the exhaust pressure. I wouldn't go lower than B4 or B5, raise the timing to 6 or 7 and use 93+ the whole way, set fuel to 8 or 9 as that is boost dependent anyways. I get better mileage out of my revo 2 big injector tp file than i did on the stock file, revo 1, or apr 1.
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    What are you gonna do if someone messes with you and you got 0 boost
    I wouldnt touch anything is that was me !
    Just dont step on it if you wanna save up some fuel...
    Veteran Member Three Rings schizzy's Avatar
    Jun 29 2009
    2008 SRT4
    New Jersey
    i have mine set to
    6 boost
    5 timing
    9 fuel
    and im averageing 27-28 mpg and im not losing performance, plus i dont think setting boost to 0 is a great idea....
    Ocean Blue b7 a4: -Revo stage II -apr/BB exhaust w/ tp -eibach/kw coil overs -19" sportec mono 10 -forge dv -rs4 swaybar -rs style grill -euro jet pcv fix -apr snub mount -custom intake -m3 spoiler -35% tints...... TOTALED BY DUMP TRUCK
    Current: 1990 vw
    Established Member Two Rings palestar's Avatar
    Aug 20 2010
    07 Porsche 987S
    Sarasota, FL
    Just take it easy on the pedal.. I've got Stage 2 Revo and pull 32mpg on my highway commute everyday.. light pedal = no boost
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Would B1 T6 F0 be ok to use for fuel economy? Apparetly that is stock boost, 93+ octane and stock AFR which I assume is leaner than the performance AFR. Correct me if I am wrong or if this combo is dangerous
    All go no show
