Results 1 to 16 of 16
Thread: Speedo
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    Question Speedo
    Is there anyother reason other than my speed sensor that would cause my speedo and my odo not not work at all... driving my car i cant tell how fast im going and im not putting any miles on my car... cluster? speed sensor? what could it be
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    Quote Originally Posted by vortexjunkie View Post
    Teach me this trick!
    I believe the Vehicle Speed Sensor (not engine speed sensor) is what communicates with the spedo. Not 100% on this though and I have no idea how your miles stopped. Almost seems like your issue is your cluster.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Sep 12 2009
    Manteca/Lathrop
    i would love to know what the hell i need to do...
    Aug 12 2008
    Rochester, NY
    You could try resetting the connection of the cluster. There is a cluster removal DIY somewhere.
    Sometimes moisture and vibrations can cause this connection to be iffy. I believe it's a big purple, don't try too hard or you'll break me, electrical connection.
    E85!
    Sep 12 2009
    Manteca/Lathrop
    im going to try that when i get home....
    Registered Member One Ring konekiller's Avatar
    May 25 2009
    this space is too small
    Louisville, kY.
    My speedo stopped working a few weeks back and it was the ABS module( Bosch 5.7) after the drivers front wheel speed sensor had failed. Have both checked and I hope the drivers front wheel sensor will fix your problem.
    Aug 12 2008
    Rochester, NY
    someone please help me
    You're not going to get much more help. The issue is your cluster, your VSS, some random fuse/relay or the ECU.
    Start with diagnosing the cheapest option first, fuse/relay, and then go from there.
    If you want to just spend money and pray. Buy a new VSS.
    If you don't own one right now go buy a Bentley because it's the only way to track down electrical gremlins.
    Quote Originally Posted by konekiller View Post
    Was your ABS light lit up? If so, OP is your light lit up?
    E85!
    Active Member Two Rings henriquevr's Avatar
    Oct 11 2010
    Sunnyvale / California
    Some one already mentioned, it is abs module front wheel. have it checked. good luck
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    did the speedo stop working all of a sudden or did it die slowly?? On my C5 it started dying slowly/randomly and it was the speed sensor that crapped.
    Sep 12 2009
    Manteca/Lathrop
    just stopped all together... after i did my trans replacement... im checking the speed sensor first... my cluster is fine everything works on it with the exception of the speedo and the odometer... talked to mike at ringer said that it can only be a couple things speed sensor cruise control module or a broke wire... abs has no play as the speed sensor is on the trans that controls the speedo.. and no my abs light isnt on...part number for the speed sensor is 012 409 191D
    Oct 11 2010
    check transmission speed sensor for short or fault.
    Sep 12 2009
    Manteca/Lathrop
    i ordered myself a new Speed Sensor on the trans today... for 26.50 i can afford to be wrong...
    Oct 11 2010
    is easy to check just need a multimeter and time.
    replacing will work if it is a faulty part.
    PS: you mentioned that had your transmission serviced. maybe, just maybe they forgot to securely connect the sensor. It could be just hanging out some where. (?)
    Established Member Two Rings Xmenpl's Avatar
    Nov 25 2009
    Long Island
    My speedo needle died along with Traction/ABS/Brake light on the cluster.
    Car doesnt record the mileage along with MPG recordings. I drove like that almost entire trip from NY to H20.
    While it happened I had vag-com connected, scanning codes revealed I lost signal with ABS Module (vagcom couldnt even connect ti it) - possible loose wiring/harness.
    Sep 12 2009
    Manteca/Lathrop
    checked all connections in the car every wire when i did my fount mount... even last night reached down and pulled plug off checked pins and connection and that was what i did...so today i ordered new part... i will let you guys know what happens
