Is it normal for Slotted rotors + Hawk HPS to make a grinding/humming noise when braking hard.
I just installed A8 Schwaben slotted rotors + TT carriers + Hawk HPS
http://www.ecstuning.com/Audi-B5_A4-...rake_OEM/ES90/
When I test drove it made a noticeable sound when braking from low speed (around 25mph). I then rechecked everything, everything was tight. Then did the Hawk break-in method. Now it only makes noise when braking hard from higher speed (around 45mph).
Is it normal for slotted brakes to make this noise. It almost sounds like grinding with a beat.
EDIT: Is there a Left and Right rotor? I didn't see any markings, so I installed them with the slots going rearward @12o'clock. The vents are straight.
