Results 1 to 20 of 20
    Account Terminated Four Rings
    Feb 16 2009
    Ithaca New York
    Is there a way to test your Auto Aim Headlights?
    I noticed that my S4 got auto leveling headlights but personally i never see them adjusting themselves. On my buddies friends BMW they level as soon as he turns on the car and you can clearly can see the auto check. What about ours? How do they work?
    Aug 17 2009
    Pittsburgh
    They should sweep down to up every time you turn them on as they charge up.
    Feb 16 2009
    Ithaca New York
    Thats what im saying. I never notice mine doing that. I will put the car pointing to the wall and check again but im pretty sure they dont do that. Is there a fuse for Auto Leveling System?
    Veteran Member Three Rings Avant Fetish's Avatar
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    If you have access to a Vag Com...you can do it through that.
    All it does is it moves the headlights up and down...
    I've never seen mine move at startup.
    Cup | Corrado | Cervelo S2 | Banshee Spitfire | Evil Following
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    it's a lot more subtle than BMWs i believe. did all B5S4s get these?
    '17 Ibis White B9 A4 quattro P+ S-Line
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    I think the cars with Xenons got them.
    The BMW lights are "adaptive" you can see them move when you take a turn. Those self align at startup.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    the S4 will move a little depending on the pitch of were you are or the sensor is
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Feb 16 2009
    Ithaca New York
    So i am a little confused then. Whats the point for our system? It goes up and down but what for? I mean on a regular car you level it once and you are done right?
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    it changes as the car tilts it is suttle at best if you are lowered, my stock ride hight avant moves more than my lowered sdn dose, as for why our cars have it is one more thing to break down the road lol
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Quote Originally Posted by Emilgevor View Post
    I guess if you have a heavy load in the back that pitches the front of the car up...the auto level will move the lights down.
    Feb 16 2009
    Ithaca New York
    ^^^ thats actually a good point but since I carry noone in my rear i guess this feature is useless for me...
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    as you drive up or down hills it adjusts the angle. I was driving up a big hill the other day and instead of the lights pointing out into the sky they aimed down at the ground.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Senior Member Three Rings Marioh's Avatar
    Jun 26 2010
    In Europe it's required that all high intensity discharge headlights have an auto-leveling (or commonly called adaptive lighting) system linked to the suspension of the car.
    The US requires all bi-xenon (this means the high beam is in the same lens as the low beam) headlights to have adapting headlights.
    Active Member Three Rings
    Jun 16 2007
    Melbourne
    I only notice mine during startup, and only when I have been parked on a hill. Sometimes, if I'm stopped on a steep hill, it will adjust itself after a second or two.
    Feb 07 2008
    The boonies, near Seattle
    Put a bunch of weight in the trunk, turn the car on, and you'll see them adjust.
    From my understanding, the headlights will only auto adjust if they see a leveling difference.
    -dre
    Sep 11 2009
    NE
    It is very visible once you chip or go stage 1+ and you gun the car on low gear so that squats heavily. You will see the lights staying planted on the road instead shooting up the trees like a car without the leveling system would do.
    Veteran Member Three Rings lbs4's Avatar
    Jun 14 2009
    01 S4.99 Grand Cherokee.89 240SX
    Vermont
    mine never adusted so i unplugged my sensors and clean 10 years of dirt out of them. plugged them in and they started adjusting on their own. my problem was every start up my motor would just point straight up at the trees on my drivers side. that solved my problem
    Feb 16 2009
    Ithaca New York
    you cleaned all 4 of them? the once that connect to your lower control arm?
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Mine adjust when I turn the lights on. It's very subtle, but definitely noticeable.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    There's two of them, one in each headlight.
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
