Results 1 to 11 of 11
    Sep 09 2010
    Värmdö Stockholm Sweden
    Thinking of getting 16" 205 tires even on summer...
    Yesterday i changed my Summertires 235 45 17" to my wintertires 205 55 16...
    I almost directly lower from my fuelconsumption... i went from 21 miles per gallon to 28 miles per gallon... and my consumpton on the screen in car is usally correct...
    Also my comfort got alot better and car dont "track" at all (dont know what its called in english) but when the tires follow unevenness in the road rather then going straigt) 235 can track alot
    Im really considering going 16" and narrower tires due to the fact that we in Sweden pay about 8,87$ per gallon
    So is there anyone else out there that driving on 16" on summer tires? or should i be ashamed even thinking of going 16"? (last one is more or less an joke)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Your mileage should have increased, but not by the amount indicated on your display. You have decreased your rolling radius by ~2% and consequently the display will be off a little as well as your speedometer. When I went from 235/45/17 to 235/40/18 my mileage dropped by ~ 2 mpg and the wheel/tire combo weighed the same. It's all tied in to the location of the rotational mass. Even with the same OD and same total weight the larger wheel moves the mass further from the mid line. Smaller wheels and skinnier tires will definitely give you better mileage.
    Sep 09 2010
    yes i know the display can be a little off, but not that much... i will see in a couple if fíllups how much off it is... but if i can get 6mpg more with 205/55/16 Studded tires I must get even better with 205/55/16" summer tires?!?
    And with our gas prize thats alot of money just for the good look...
    But the question is how much better mpg will a change from 235/45/17 to 215/45/17 give?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Le31504 View Post
    But the question is how much better mpg will a change from 235 45 17 to 215 45 17 give?
    Little if any. All you will do is decrease the rolling radius but maintain approximately the same location of the bulk of the rotational mass (wheel).
    Sep 09 2010
    hmm ok...
    But the width of the tire should have some to do with it... Less road contact should mean less consumption?
    Dec 28 2006
    Western Maryland
    hmm ok...
    The width of the tire does have an effect, but probably not for the reason you think. The size of the contact patch has more to do with the diameter of the tire and the weight of the car. A narrower tire of the same diameter on the same car will have essentially the same road contact area. What changes is the SHAPE of the contact area. what affects the mileage more is the increase in CD or drag that results from the wider tire.
    Sep 09 2010
    ok... so if i want to save gas the 16" is the way to go rater then buying 215 inch insted of the 235 i got?
    Dec 28 2006
    Western Maryland
    You are correct. Reduce the radius of the bulk of the rotational mass and you will reduce the energy required to accelerate/decelerate and consequently your mileage will increase.
    Sep 09 2010
    ok thanks!
    Well i think that the economy in this case will win over nicer looks...
    And i think i will have quite good traction due to quattro even with 205s.. i hope anyway
    Dec 28 2006
    Western Maryland
    At $8.87 per gallon I can certainly understand your logic. And unless you are pushing your car to the limits I doubt the performance difference will be all that noticeable.
    Sep 09 2010
    yea... its expensive to drive here in sweden... or well the gas itself is not so high... the taxes are... and not just the gas taxes are high... the income tax is at 32%.. so well it sucks :-)
    Also to go with 205/55/16 is like 30-40% cheaper then the 235/45/17
    I dont usually drive at the tracks, but sure i want to do some highspeed / tight corners sometime and i hope the 205 can keep up with me :-)
