Results 1 to 19 of 19
    Feb 25 2009
    Mk2 Jetta, B5 S4, B5 A4
    New England
    Fustrated by misfires (w/ codes and troubleshooting steps that I've taken)
    I just bought another S4, and it was misfiring when I got it. CEL was on, and at one point it was even flashing at idle...
    Scanned and got these codes:
    4 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 ** 35-00 - -
    16686 - Cylinder 2 Misfire Detected
    P0302 ** 35-00 - -
    16700 - SAE: Engine Misfire Detected on Startup (First 1000 Revolutions)
    P0316 ** 35-00 - -
    16690 - Cylinder 6 Misfire Detected
    P0306 ** 35-00 - -
    1. Swapped coils on cylinders 2 & 3, and 5 & 6. No change. All the same codes.
    2. Swapped the positions of the ICM's. No change.
    3. Checked the gap on the plugs and it was correct at .028. Removed the NGK plugs and replaced them with Bosch F5DP0R. No change...
    4. Pressure tested and the only leak I could hear was from the typical brake booster line at the "T". Covered the outside with JB weld, no more leak.
    5. Took the throttle body boot off to inspect it, and didnt see any tears or cracks. Noticed one of the vacuum lines to a diverter valve was in bad shape, so I replaced it.
    The car seemed to run better, no CEL but still a little rough. Scanned and got these codes:
    3 Faults Found:
    P0300 ** 35-00 - -
    16688 - Cylinder 4 Misfire Detected
    P0304 ** 35-00 - -
    16699 - SAE: Crankshaft Position System Variation Not Learned
    P0315 ** 35-00 - -
    16689 - Cylinder 5 Misfire Detected
    P0305 ** 35-00 - -
    Where do I go from here?
    Any help would be appreciated, thank you.
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    Check the grounds on those coils that are bad.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Feb 25 2009
    New England
    Quote Originally Posted by a4_1.8t_01 View Post
    ground on the coils?
    Senior Member Three Rings NefMoto's Avatar
    Jul 02 2009
    Vancouver
    Are there any mods on the car?
    For information on ME7 ECU tuning, free ECU flashing tools, and free tunes, check out www.nefmoto.com
    Please post in the forum before sending me PMs. I suck at replying.
    Feb 25 2009
    New England
    Quote Originally Posted by NefMoto View Post
    completely stock. forgot to mention that in the original post...
    Jul 02 2009
    Vancouver
    You could try running with the MAF disconnected to see if it is related to the MAF or O2s, but that is a long shot.
    I don't like this error code: 16699 - SAE: Crankshaft Position System Variation Not Learned
    Does that error code stay around after driving the car for a while?
    Feb 25 2009
    New England
    I will try running without the MAF tonight and see what i get for codes.
    I don't like that code either... and I cant find any info on it. It seems to only appear after driving it around. When I just let it idle, it only comes up with the misfire codes.
    I have 6 new coilpacks, a new crankshaft position sensor, and new fuel filter on the way...
    Running out of ideas.
    Veteran Member Three Rings ski&drive's Avatar
    Feb 22 2010
    00 S4
    Metrowest Boston
    do you access to vag-com?
    Log block 112 and see what your getting for the egt's If its doesnt stay at 945 degrees then thats your problem.
    As suggested above the Maf and 02's are a good place to start
    the crack sensor code could be because its misfiring.
    Feb 25 2009
    New England
    Block 112 is showing exactly 945 degrees
    Watching block 15 (supposedly cyl 1-3) shows misfires that count up fairly slowly. The most I saw was about 40. Most of the time its only showing 3 or 4 before it resets to 0.
    Block 16 (4-6) isn't showing any misfires
    This is all at idle. Scanned and got the same exact codes as in the original post. Random, cyl 6 and 2 misfires.
    Unplugged the MAF and ran it, showed the same misfires on block 15 but no misfire codes. Just the code for unplugged MAF. I'm not convinced though...
    Feb 25 2009
    New England
    Plugged the MAF back in and got random, cyl 4 and the crank position code again....
    Jul 02 2009
    Vancouver
    Verify that your car is idling at correct vacuum using VAG-COM or with a boost gauge. If vacuum is correct, get a remote fuel pressure gauge and check that fuel pressure is 4bar above the intake pressure.
    I'm running out of ideas, and I'm not willing to start telling you to randomly replace things. It could be the crank sensor though, and I am not sure how to test that.
    Feb 25 2009
    New England
    Thanks for the help, I appreciate it.
    Ill look into the vacuum. My boost gauge doesn't read vacuum so I guess I need to find it in vagcom measuring blocks?
    After that ill have to borrow a fuel pressure tester.
    All new coilpacks, crank sensor and fuel filter will be here tomorrow so we'll see if any of that fixes it.
    Senior Member Two Rings Aphex350's Avatar
    Feb 11 2008
    Peekskill, NY
    Did you ever resolve this?
    2000 Santorin S4
    AWE Stage 3+
    Feb 25 2009
    New England
    Quote Originally Posted by Aphex350 View Post
    I never did resolve this and I just got around to messing with it again recently now that the car is out of storage. Sorry for bumping an old thread.
    I've just replaced all of the coilpacks, and the crank position sensor. Still have the same codes in the original post, with the exception of the crankshaft position one.
    I'm starting to suspect MAF or 02's at this point
    Veteran Member Four Rings s4boost's Avatar
    Jan 08 2008
    Franklin/TN
    i had the same issue on my car for months. god forrbid you have to go through it, it ended up being a bad cam, the edges of the lobes were rough seemingly from oil starvation, as were the lifters, and there was a very very slight amount of buildup on the valve seats. i you cant find the issue, you may wanna check that. cost about 3,000 to get fixed. pulled the engine, pulled the head, machine shop, new internals, put it back together. PITA
    2012 S4 Ibis White S Tronic Prestige APR stg 2+ V3 CTS Turbo Intake
    2002 Silver S4 6MT Premium Package Stg 3 -SOLD
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    I didn't see any compression tests or anything about you moving injectors around. Also how much vacuum are you pulling at idle?
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Quote Originally Posted by P0234 View Post
    I'm thinking and wondering the same...
    Mar 18 2010
    Ottawa
    Definately a compression check. Got to look up the misfire 101 thread.....
    And ya, same as above.
    Jan 31 2007
    irvine
    the harness to the coils get really brittle and can cause the ignition coils to misfire i have replaced a few on different vehicles
