Results 1 to 14 of 14
    Established Member Two Rings wpkaudi's Avatar
    Jun 10 2010
    04 gsxr 1000 giant tcr full durace full hsc carbon fork
    cortland ny
    Angry rai test pipe no cel?
    Anyone else purchase the rai testpipe with the long bung that is suppose to not give a cel? I bought one and I still get a cel. Codes say it secondary o2 sensor and intake temperature to hot. I am going to wrap the pipe to see if it will help. Anyone have any suggestions?
    2001 a4 1.8tq tip 20% tint /18 rs 4 reps / h&r race springs/bilstein sport/ n710 dv / stg 1 Apr /k&n/ ecs vdo kit/rai tp/ hotchkiss
    Jun 30 2008
    Erie, Pennsylvania
    Post the actual codes. That may help.
    Jun 10 2010
    cortland ny
    Grrr... I don't have them :( I kinda know what your saying, cause as soon as I got chipped I got a code for o2 sensor but no cel. Maybe it is just the heat and after I wrap it the test pipe, it will be fixed. Was hoping someone would say adding a washer to the o2 sensor or a reflash. Ok this weekend I will wrap the pipe write down codes. Thanks for response walky talky.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    How about welding the tip of the OČ spacer?
    No air will get to the sensor. If it doesn't work, you can drill it to normal...
    Jun 10 2010
    cortland ny
    Quote Originally Posted by FNK View Post
    Say what? Can you explain in mote depth the process and why it will work? As for drilling its got a long j shaped bung that makes the test pipe cel proof.
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    just get flashed to stage 2... its free...
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jun 10 2010
    cortland ny
    Quote Originally Posted by bigblue View Post
    I saw someone else post something about a reflash to fix the problem, but I wanted to get confirmation. Cool, I will call and setup an appointment with where I got my flash. I need to drive 80 miles one way and they say 25 bucks for computer time. lol. Thanks, once I get my new rims I'm have to showem all my upgrades.
    Jun 10 2010
    cortland ny
    sig updated.
    Jun 10 2010
    cortland ny
    Ok was going to get stage 2 but cel went away. Must be u needed to let it break in. Thought u only had to do that with a full exhaust.
    Active Member Three Rings
    Aug 10 2009
    Space
    ECU needs to re-adapt to the new values. What it used to see as "normal" was different then the new value it was seeing.
    -John
    Jun 10 2010
    cortland ny
    That is what the tech told me when I first got chipped. I didn't realize or believe that electronics behaved in this manner so strongly. Now I believe.
    Aug 10 2009
    Space
    Same thing when you clear all the codes, you need to drive it for a while to be able to have them set again to pass a state inspection. At least now you know, I think the same thing may happen if you reset your ECU.
    Jun 07 2009
    What garage... Oh you mean the storage pit
    New Braunfels, TX
    Bringing this back from the dead.. I just finally got my rai test pipe installed and i'm getting the following codes:
    Monday,16,May,2011,19:37:01:01359
    VCDS Version: Release 10.6.4 (x64)
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Control Module Part Number: 8E0 909 518 AK HW: 8E0 909 018 A
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 0016711
    Work Shop Code: WSC 79925 924 435782
    VCID: 79F212BF4949
    2 Faults Found:
    16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
    P0139 - 004 - No Signal/Communication
    16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
    P0140 - 004 - No Signal/Communication
    Readiness: 0000 1100
    Jun 10 2010
    cortland ny
    Ok it's not perfect. Either go. It's because extra heat to intake cause no cat. Either have reset our drive it wil go on off worse in summer i wrap mine this year. Ok out lol
