Results 1 to 7 of 7
    Veteran Member Four Rings prizmatik's Avatar
    Dec 15 2009
    Hell hole
    Ko3 Turbo Question
    Check out the picture of my turbo. It was making a drilling sound when operating, and eventually started blowing a lot of smoke. My question is, Are all Ko3 turbos compatible from different cars? They appear to all look the same? I am looking to purchase a used stock turbo from a MKIV Jetta, to put on my 1997 A4. Thanks for the input.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Nope, only K03's from the longitudinal platforms will work. However before you do anything, you need to figure out what your turbo ate. If not, it could very well happen again. Go over your intake tract with a fine tooth comb.
    Dec 15 2009
    Hell hole
    Dammit! Jetta's engine are transverse? Just curious, what is the difference in the turbos?
    Sep 23 2007
    if you put the 2 side by side you notice the jetta k03 has a completely different exhaust housing.
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    the jetta turbo cold side points up (a4 ko3 points down) jetta hot side points straight back whereas the audi one points to the right of the cold side.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Mar 27 2010
    solar system
    Compressor housing, turbine housing, you may be able to use the center section, but I wouldn't count on it. Far better to buy the right turbo, I think there's one in the classifieds.
    Dec 15 2009
    Hell hole
    Thanks for the help guys.
