Results 1 to 4 of 4
    Jan 19 2009
    RI
    coolant capacity 2.7t?
    Hey does anyone know how much uncut coolant is needed when doing a timing belt job if draining the system on a A6 2.7t? I noticed some kits come with four 1.5 liter g12 bottles and others come with just two, the kit I got came with two 1.5 liter bottles of Pentosin, should I get two more or just split the two with distilled water and not worry about it.
    Established Member Two Rings gfro1234's Avatar
    Nov 27 2008
    Mountain View, CA
    Quote Originally Posted by B5 Bandit View Post
    I use 50% coolant 50% distilled water. Unless you live in super hot or super cold temps I think you should be ok with 50/50 mix
    Current: 2014 Audi S4 (manual)
    Previous: 2011 Mitsubishi Evo X (manual), 2001 Audi S4 (tiptronic)
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    from what i can remember talking to the parts guys, the system takes 2 gallons +/- a couple of ounces
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jan 19 2009
    RI
    I guess I'm trying to figure out if I will have enough with just the 3 liters undiluted and 6 diluted if I have to drain the system from the bottom.
