Results 1 to 10 of 10
    May 03 2007
    Bay Area
    Implausible signal / misfire on Cylinder 4???
    So I've been having my CEL on for about a month now. VAG shows:
    2 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal
    16688 - Cylinder 4 Misfire Detected
    P0304 - 008 - Implausible Signal
    I keep clearing but they keep coming back. My coilpacks, spark plugs, and battery have been replaced recently. Also CEL flashes when I'm at a stop light or idling, although idle is not rough. Not all the time but it's happening more frequently. I searched and I couldn't find any threads on just Cylinder 4 misfiring. I replaced all check valves even though original ones didn't look bad. Also cylinder 4 didn't have any traces of oil leaks. What else should I look for?
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Swap a coil packs between cylinders and see if the misfire moves, I know you said that the coil packs have been replaced but it sounds like a cp issue. Also check your gap on plug 4. You can also swap the plug to see if the misfire moves.
    May 03 2007
    Bay Area
    Jflow23,
    I did swap coilpacks and it still CEL's on Cyl 4. New NGK plugs gaps are within specs. I forgot to mention that on my first post.
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    swap injectors.
    May 03 2007
    Bay Area
    Swapped Injectors 3 and 4 and still getting misfires on cylinder 4. Cylinder 4 is closest to front bumper right?? So coilpack, spark plug, and injectors have been cleared. Also no signs of oil in Cylinder 4 so gaskets aren't leaking. Anything else to look for?
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Two more things it can be.
    - Visually check for broken/cracked wires in the coil harness. Also, while the car is running, tug on the harness, and see if the misfires change.
    - Next is not good news. Do a compression test. You may find that the suspect cylinder has low compression, and as such not enough to get proper ignition.
    Please report back.
    Apr 09 2007
    Beaverton OR
    Quote Originally Posted by audballz View Post
    No...other way Click for additional reference
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Dude I didn't even catch that when he typed it. Maybe it's just a coil after all. :) Crosses fingers...
    May 03 2007
    Bay Area
    Thanks guys will start from scratch now that I know which cylinder is which!!!
    Aug 26 2005
    The two seperate misfire codes are actually the same problem, not two seperate problems.
    Vorsprung durch Technik
