Results 1 to 24 of 24
    Jul 23 2010
    Dentist drill under my hood
    00 1.8QM
    When i start my car it sounds like there is a dentist drill towards the left side of the engine. It has a code for Sec air flow but when someone checked the vacum lines they all seemed to be in place. the sound last for about 20 seconds then it seems to idle fine. Also when under steady acceleration it seems to kick/bog down for a split second then it runs fine. ANY tips/suggestions as to what could be causing the sound/hesitation?? THANKS!
    Aug 13 2008
    Indiana
    Quote Originally Posted by s4dc3 View Post
    00 1.8QM
    Is this a joke?
    search "dentist drill" .......................
    -Nic
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    1.8QM
    He answered his own question right here.
    Current:
    2005 Black W211 E55 AMG
    Sold:
    2002 Stering Grey E39 M5
    2001 Nogaro Blue S4
    Jul 23 2010
    im guessing what you are trying to say is my turbo is going bad??
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Do you happend to know what a turbocharger is?
    You need a new one.
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Aug 13 2008
    Indiana
    -Nic
    Established Member Two Rings gfro1234's Avatar
    Nov 27 2008
    Mountain View, CA
    Quote Originally Posted by SantorianA4 View Post
    You need a new one.
    Hold on now guys, this sounds like it's just a secondary air pump failing. Mine used to do the same thing. Even after I got new turbos it still did it only upon cold starts. (The turbos happened to be blown, but I also thought the noise upon startup was due to the turbos) If it's only making this noise on startup and not under acceleration then it's an indication of a bad secondary air pump not a bad turbo.
    We'll put it this way: don't go pulling out your turbo until you're positive that's whats making the noise (and it sounds to me like it's not). Good luck
    EDIT: Assuming it is the secondary air pump, that noise means that it is on its last legs but that it is still working :up:
    Current: 2014 Audi S4 (manual)
    Previous: 2011 Mitsubishi Evo X (manual), 2001 Audi S4 (tiptronic)
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    He said left side of his bay... as in the drivers side guys. The guys in the b6 forum tend to jump to say a turbo is bad, so I guess you guys do as well. I was told mine was bad but mine doesn't whine anything like the two videos... and only at above 5psi which you can't get at idle with a ko3. Plus he said its only when idling thus the turbo isn't spooling and it would have to be sai pump related.
    Now onto trying to help. Crawl under your car and unplug the power cable to the sai pump and then start it. If it doesn't make any noise then you can assume that the pump is whats wrong.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Aug 17 2009
    Pittsburgh
    Quote Originally Posted by bigblue View Post
    good advice! but the sec air pump is on the right side, the pass side-not the left(drivers). what about the aux water pump?
    Nov 27 2008
    Mountain View, CA
    Quote Originally Posted by hercfe View Post
    Maybe he was looking at it from the front of the car
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Ya I know where the pump was, I was just saying its not the turbo. So the real question is what besides the sai pump an combi valve work for the first 20 seconds of running and then stop?
    Jun 20 2009
    98 A4 Quattro, 02 Eclipse
    Temecula, CA
    vacuum pump
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I was thinking about that but doesn't the vacuum pump only come on automatics?
    Jul 23 2010
    Seeing as how it only makes noise on start up and i have a CEL for sec air flow im leaning toward a vacum issue. And yes the noise was coming from passenger side of engine
    Aug 13 2008
    Indiana
    I said turbo because it's stuttering under boost....
    -Nic
    Established Member Two Rings Spanky387's Avatar
    Nov 11 2009
    01 A4 VRT MK2 GTI Turbo
    651 minnesota
    vacuum line from the combi valve to the intake manifold is known for going bad.
    Jun 30 2008
    Erie, Pennsylvania
    *BINGO*
    Passenger side of engine + drill noise during first 30-ish seconds on a cold start = Secondary Air pump is bad.
    Best bet is to find a used one as they are $Cash Money$ for a new one from the dealer. Probably under a hundred bucks for a used one. If you don't mind the CEL, and don't have to pass emissions, you can just unplug the thing and be done with it. It's only purpose is cold start emissions, nothing to do with how the car runs.
    Aug 13 2008
    Indiana
    So whats causing his stuttering? Until thats resolved I stick to turbo
    -Nic
    Jun 30 2008
    Erie, Pennsylvania
    Stuttering is probably just a dirty MAF or an ignition problem (coil pack, plugs, oil in the plug holes, etc). I believe that issue to be separate and not at all related to his cold start noise. The fact that the noise stops after a set period of time points directly to the SAI pump and nothing else.
    Jul 23 2010
    Thanks ya'll
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I've got two pumps for sale. Unplug the sucker and see if the noise stops like I told you. its just one plug.
    Senior Member Three Rings DRock3d's Avatar
    Sep 20 2010
    Mansfield, Ohio
    Sai, I have mine unplugged and I get a p0411 but my car runs great regardless.
    See that plug hanging down? That's the plug for the Sai.
    Ps: Excuse the hideous headlights and emblem, I took care of those the day I got the car home. I also zip-tied the plug out of view.
    2001 A4 1.8T Quattro - 3 Pedals-Short Shifter-GIAC-3" Turbo Back-VMAXX-710N-Neuspeed Sway Bars-Phat Box<3
    Badass enough to get pulled over on suspicion of being a Gangster
    Jul 23 2010
    im thinking about removing the whole SAI system since the pump is most likely poor anyways. however im not sure what the emission reqs are for my area
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Just get unitronic and have them code out sai and your cat and be done with emissions stuff.
