Results 1 to 11 of 11
    Sep 17 2010
    perth,scotland
    K03-73 worth it?
    Is it worth fitting a K03-73 from a b6 as a small upgrade? I think they are about the same spec as a K04 but i could be wrong?
    Apr 22 2009
    new zealand
    Probably only if your k03 needs replacing. what year and mods have you got?
    Oct 06 2004
    Minnesota
    Don't expect an upgrade.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    If what you're running now is a K03-005, then the -073 is a sizable bump in output. It can handle any K04 flash commonly out there and is good for 40bhp more than a -005. If you can get one cheaply do it!
    Sep 17 2010
    perth,scotland
    Im on just the normal k03 on the AEB engine. Running a chip and about the 200bhp mark or should be anyway. I know its not going to make a big impact but if they are about on a par with a k04 i was thinking it might be worth a shot.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I don;t think they are on par with a K04. Probably closer to a K03s setup.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 17 2010
    perth,scotland
    It is a k03's. I think the turbine is smaller than the k04 but the compressor side is the same or slightly larger.
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    if yours is not shot, you would be stupid to do this 'upgrade'...
    if its shot, it cant hurt, you wont feel any difference, i promise you that...
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Feb 10 2009
    '01 A4, '87 Chevy 1 Ton
    Knoxville, TN
    talk to slappy dunbar about his frankenturbo kit. for the money it looks to be a damn good deal. I am gonna go this route.
    1988 Shelby Dodge CSX-T, 2.5L 4cyl, T04E 40 trim w/ .63 A/R, Stg2 Ported 8v Head (Sold) it was a torque monster!!! :(
    2001 A4 1.8T turbo back 2.5in exhaust, SB clutch w/ 17lbs SMFW, Forge splitter, Revo stage 1 flash, 4:1 Center diff, ST Coilovers, 034 RSB, Forge FMIC.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by flynnr View Post
    sorry to bring up an old thread, but that is false. I ran a k03-073 that slappy had gotten on accident with a larger wastegate port and uprated actuator. I ran the PC-16 setup on the turbo without any issues but I also did bump up from a GIAC chipped k03-005 and it was a night and day difference. I have the dyno chart around here somewhere but i was just shy of 200awhp (around 193 I want to say) with that setup.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Sep 17 2010
    perth,scotland
    My car is chipped at the moment but no idea what chip it is. I was just thinking about one of these as a cheap upgrade. I know of one going cheap you see.
