Results 1 to 2 of 2
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    Having idle problems after head gasket install.
    The car is a 2001 a4 1.8t awm engine. When I started it the idle bounces a lot and the car dies after a minute. I get misfires codes and a p0638 for throttle actuator circuit. Check engine light flashes and EPC light is on. Also when trying to do a tba the throttle body noise is very loud like its malfunctioning but works after that.
    For some reason fuse 32 I believe for the ecu 20amp blew out. Replaced it and fixed the wires I believed caused it from the coils shorting. So far ive checked done:
    Checked all the fuses.
    Put in spare TB and have the same noise.
    Reset everything by touching battery cables together
    Checked timing belt and marks line up good.
    I can spin the crank with no problem.
    What do you guys suggest?
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Feb 24 2008
    A4 1.8TQM 01
    All fixed. A manual tba actually worked. Also had a faulty coil. Finally running again
