    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    Quick after run sensor install question.
    I just got my new sensor from pure ms that is supposed to keep the fans and after run pump on after shut down. The only question I have is were does it go? My friend has an 01 and his is on the driver side behind the head...but on my 00 I couldn't see it there and mine seems to be on the pass side? Any help would be appreciated
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    On the driver side kinda down a little from the head. Probably has a green connector on it now and looks just like the CTS on the passenger side.
    Nov 09 2009
    tri-state
    Yea I looked in there and I see it now...so I just replace that and that's it...it will cool off after shut down?
    Established Member Two Rings BITURBOB5's Avatar
    Apr 24 2008
    01.5 S4
    Harrison
    Yes replace that then take it for a ride for like 15 min get the car warm then turn it off because it won't just run the fans when u put it in the car has to be driven for alittle
    Sep 03 2010
    Nashville, IN
    +1 Be sure to replace the rubber O ring as well and the clip if it breaks or has a crack.
