I'm getting code P1128 (Long Term Fuel Trim mult.,Bank1 System too Lean)
First of all, the car is a stage 3
Well, I've been having start up issues for a while now. It basically started one morning when I tried to fire the car up and it took me about a minute to do so. It seems as time goes by/ the colder it gets that it takes more and more to start it up.
-I checked the ignition first. I got a little shock on all 6 coils so I'm assuming that ignition works properly...
-Next was the fuel filter which I changed. No change
-Then, I switched to a new fuel pump. No dice
-I switched the green coolant sensor as someone mentioned that it might be the issue but once again, no change.
Now I'm getting frustrated (it sucks when people are staring at you, wondering why an expensive looking luxury car is having issues) and don't know wtf is going on or if code P1128 (Long Term Fuel Trim mult.,Bank1 System too Lean) has anything to do with my startup issues. I only experience these issues on cold start ups. When I crank it for about 1-2 mins on cold starts I start smelling fuel. But once the car is warmed up it will start right away with the turn of the key. No gasoline smell these times.
What else could be the issue?!?? I'm pretty sure I replaced everything that was said could be causing the issue but nothing has worked. WTF?!
