Results 1 to 13 of 13
    Established Member Two Rings Toiffel's Avatar
    Nov 12 2006
    Crompond, NY
    FOG MOD Questions ****NOOBIE*****
    So I have a 2002 A4, went and did the fog mod, but it doesn't work, so after some research I stumbled on some information regarding having to make some sort of changes with a VAG Com....
    So......
    1st Where can I get a VAG mod and how expensive is it??
    2nd How difficult is it to make the changes needed??
    Veteran Member Three Rings NetLogic's Avatar
    Jan 05 2009
    02 A4 1.8TQM Avant
    New Orleans
    Luke
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    1: ebay, cheap
    2: easy
    Nov 12 2006
    Crompond, NY
    One more.....where to I get and what kind of cable/connection from car to pc??? Or the software comes with it??
    Sep 06 2009
    Bay Area
    if youre running windows 7 64bit use VCDS Lite which is free at the rosstech website (its a demo version, but thats all you need to do the "vag com coding mods")
    use this thread http://www.audizine.com/forum/showth...gh-*Revisited* to help you with finding the right cable on ebay. have had no problems with mine at all and vag-com is arguably one of the best/cheapest mods out there
    Dec 19 2007
    York, PA
    can you still clear codes with VCDS?
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    This has def been talked about 1,000's of time...search will be your best friend.
    Out of curiosity, how did you do a foglight mod without vag com?
    Veteran Member Three Rings mattg1.8's Avatar
    Sep 16 2009
    San Diego
    is there a vag program for macs?
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by [email protected] View Post
    maybe it is an 02? i had mod my switch and then set my central electronic to ROW
    Jun 21 2008
    Quote Originally Posted by JEENYUS View Post
    Oh, forgot about modding the physical switch...makes sense.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by mattg1.8 View Post
    Not yet, I use parallels to run the vag-com software via windows. You can also run windows via bootcamp.
    Nov 12 2006
    Crompond, NY
    Tapped wire #1, cut wire #2......
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    You can also post in the regional section to see if someone local has a vagcom to help you out.
