Results 1 to 4 of 4
    Active Member Three Rings
    Jun 16 2007
    Melbourne
    Cruise Control Problem
    Hey guys,
    Noticed yesterday my cruise control is no longer working. Have checked vagcom block 066, all cruise switches are registering correctly. No error codes. Also, clutch pedal switch, brake pedal switch, are working fine as well.
    No warning lights on the dash, etc. everything else is still 100% normal.
    Any ideas? I'm going to go check my fuses; but I'd imagine the cruise switches wouldn't register if the fuse had gone.
    Established Member Two Rings asc_up's Avatar
    Feb 01 2010
    Tacoma, WA
    Mine doesn't even have a fuse for the cruise control, but it still works.
    I've found with mine, that I have to push the "set" button in and hold it for a full second and then it registers that I want to activate cruise control.
    Jun 16 2007
    Melbourne
    I think it's programmed to ignore an accidental bump to the button, similar to the ESP button.
    Anyway, I fixed the problem - turns out my clutch pedal switch was in fact playing up; get this, it showed 1 with the clutch fully out, then with my foot resting on the clutch, it would show as 0, then when I pressed the clutch in it registered as 1 again, haha.
    I wonder if it's been messing with my ignition timing the last couple of days cos the car has generally just been a little weird!
    Anyway it's all fixed now and running great again, cheers.
    Veteran Member Three Rings hernandez3011's Avatar
    Mar 21 2008
    United States
    which vagcom block shows the clutch pedal switch reading? TIA
    2001 A4 1.8TQM, Inmotion Chip, TurboXS BV+MBC, TP w/ stock exhaust, OEM S4 Bumper+ Sides
    http://im1.shutterfly.com/media/47b8...D550/ry%3D400/
