I have a 2000 S4 with a GIAC X chip, turbo-back exhaust, N249 bypass, upgraded TBB, F-hose and 710N diverter valves. Normally, I would see a ~20 PSI spike and then boost would hold at 18 PSI, but now boost slowly builds up to 15 PSI and then tapers off to about 12 PSI at redline. I pressure tested the intake system and everything holds just fine. I unplugged the MAF and floored it - same issue.
I've searched around, but it seems that people typically experience boost spikes or very little boost when their N75 goes out on them, not just a 5-7 PSI drop. I cannot think of anything else that would cause this problem with my car, but the N75 valve. Does this sound like it could be an N75 issue?
Thanks in advance for your help.
I should also mention that I am NOT getting a CEL and I have even checked for hidden codes and came up empty handed.
