Just installed my Apikol snub mount. Very easy. Hardest part was getting the GD belly pan back on. Here are some pics/comments:
First, this is my new Euro plate - I know - most people will think it means "I urinate on the law." It stands for "intellectual property law" - my profession. In retrospect, should've picked something less Bart Simpson... And yes, that's my Dolphin Gray tow cover on a Lake Silver car - don't know why the previous owner did that...
These two pics show the old mount - you can see the dark area where it was hitting the bottom of the cup - I guess that's the "clunk" we feel sometimes:
Here are some comparison shots between the mounts. The Apikol is obviously bigger. I was worried about fitting it in the cup, but it fits perfectly. I had to drop the cup all the way down to work the mount back in, but as shown below, that was the sweet spot for tightening the cup back down.
This was my prep for getting the Apikol on. I had read so much about how hard it is to jam a new one on - the Hot Dog Heaven cup has hot soapy water. I didn't need it - just peeled the old one off and banged the new one on.
Here's the fit of the Apikol:
This is the right side of the cup. As you can see, the cup is adjusted as far down as it can go - luckily that was exactly where it needed to be - no vibration.
This is the left side of the cup - notice that mine only had 3 bolts to adjust - two on the right, and one on the left.
IMPRESSIONS:
The only reason I did this mod was because I found out my OEM mount was starting to crumble. I didn't think I had any vibration issues. I do feel the clunk every now and then, but I attributed that to sloppy shifting.
After test driving around the block - wow - I can really tell a difference. It wasn't until feeling how smooth the car is now that I realize that it was a little rough before.
Very pleased with it. I hope it holds up!
