Results 1 to 14 of 14
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    A4 B5 2.8 auto - transmission fluid brands, specs, sources, quantity
    I am installing a new/used transmission in my 96 A4 2.8 quattro auto.
    What trans fluid is recommended?
    Brand
    Specs
    Sources
    Quantity
    I am sure it is not "any".
    Ditto: anything special needed for the radiator (coolant)?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Try the search button, this subject has been discussed thoroughly,
    Such as this one;
    http://www.audizine.com/forum/showth...ning?p=5431408
    Feb 20 2010
    Brighton, MI
    Thanks for the link.
    I am surprised not to find simply what AUDI USA recommends (they are responsible for the warranty for example).This should be the basis.
    And then discussions like "I have been using grape juice and acetone mix with great results" can be added as personal opinions.
    Pentosin ATF1 is obviously out of questions for normal US customers (its cheap stuff, but here in the US they charge as if it were pure gold).
    And in addition, any discussion should be trans specific, since I read somewhere that the tiptronic has entirely different fluid requirements (and certainly the variable speed trans CVT).
    05 Golf TDI
    Mar 07 2010
    Sherbrooke, Qc
    Quote Originally Posted by vtraudt View Post
    CVT and DSG transmission use a different fluid.
    As a replacement oil, I filled mine whit Mobil 1 ATF until next summer where I will change the seals.
    Here is another very usefull link for equivalent ATF oils
    http://www.taligentx.com/passat/maintenance/atfchange/
    In the end, new oil is vastly superior to used Pentosin oil.
    Each of them have seal conditionner, etc...
    I feel safe whit Mobil 1, it's supposed to be top of the line oils.
    Jun 30 2008
    Erie, Pennsylvania
    I use only Pentosin ATF1. I get it for a little under $15 per quart. It takes just under 4 quarts. You don't change it often, so it's worth it for me to put in the correct stuff.
    Feb 20 2010
    Brighton, MI
    "I feel safe whit Mobil 1, it's supposed to be top of the line oils. "
    I assume Mobil 1 Synthetic (not sure if they make other, but likely).
    05 Golf TDI
    Mar 07 2010
    Sherbrooke, Qc
    If you compare Spec to Spec,
    Mobil 1 Synthetic ATF
    Viscosity, cSt (ASTM D445)
    @ 40 ºC 36.3
    @ 100 ºC 7.4
    Viscosity Index 176
    Brookfield Viscosity, cP (ASTM D2983)
    @ -40º C 10.040
    Pour Point, ºC (ASTM D97) -51
    Flash Point, ºC (ASTM D92) 220
    Density @15.6 ºC g/ml (ASTM D4052) 0.846
    Color Red
    Pentosin ATF1 Spec:
    Unit Result
    Appearance bright and clear visual
    Density at 15 °C kg/m³ 850
    Kinematic Viscosity at 100 °C mm²/s 7,6
    Kinematic Viscosity at 40 °C mm²/s 38,0
    Viscosity Index 171
    Dynamic Viscosity at -40 °C mPa*s 14000
    Pour Point °C -51
    Taper roller bearing test,
    shear loss (20h) % 9,6
    viscosity after shear mm²/s 6,8
    FZG wear test A/8.3/90
    // A/16.6/90 failure load stage > 12 // >12
    Esso LT-71141 (the expensive VW OEM fluid) spec:
    http://www.taligentx.com/passa...s.pdf
    Viscosity @ 100ºC: 7.3 cSt (kinematic)
    Viscosity @ 40ºC: 37 cSt (kinematic)
    Viscosity @ -40ºC: 18,000 cP (dynamic)
    Viscosity index: 168
    density @ 15ºC: 853 kg/cubic meter
    Flash Point: 215ºC
    Pour Point: -54ºC
    Volatility @ 200ºC: 5%
    Foaming tendencies: S1= 10/0
    S2= 30/0
    S3= 0/0
    FZG gear test = failed at stage 12 (of a possible 24)
    Feb 20 2010
    Brighton, MI
    Here is an ad from Germany for the Pentosil ATF1. Note that it is marketed as Dexron III. Sells for the same price as other no name ATFs (not that no name ATF and any oil costs a lot more in Germany than in the US. Pentosil is sold for $7/liter like other no names).
    From other forums:
    "If you want to go ahead and try a new fluid, use Redline D4. It has the most solid track record here. Rough guess is maybe a combined 200,000 miles (?). M1 seems to work fine, but it's not got many miles on it."
    "Febi Bilstein / Pentosin (insert generic brand here) that can be looked up via the VW OEM part number all are merely repackaged bottles of EssoLT 71141 which is the OEM fluid."
    "According to my very recent email from ZF, the OEM Esso juice is the ONLY fluid the transmission manufacturer recommends"
    For the ZF 4HP/5HP, for example, Ravenol is also used:
    Ravenol ATF 5/4 HP Fluid:
    Dieses moderne vollsynthetische Getriebeöl ist durch eine spezielle Additivierung
    auf moderne 4 und 5 Gang ZF Getriebe abgestimmt und gewährleistet eine einwandfreie
    Funktion Ihres Automatikgetriebes. Geeignet für ZF Serie 4 HP Getriebe
    (4HP20, 4HP22, 4HP24) für 5 HP Getriebe (5HP18, 5HP19, 5HP24, 5HP30)
    Pentosin ATF 1
    Dexron III - Automatikgetriebeöl
    vom Erstausrüster Pentosin!
    - Made in Germany -
    Dexron III Getriebeöl entspricht:
    VW TL 521 62
    BMW Oil No. 83229407807
    Citroen Oil No. Z 000 169756
    Jaguar Oil No. JLM 20238
    Mercedes Benz Oil No. A 0019892203
    Peugeot Oil No. Z 000169756
    Porsche Oil No. 999.917.547.00
    05 Golf TDI
    Mar 07 2010
    Sherbrooke, Qc
    Excellent information!
    If ZF choses to only list Esso oil as the ONLY viable solution, it is most likely only for warranty, as this restrict everyone from trying everything and then be pissed at ZF transmission. This create bad press for ZF, even if it's not their fault.
    As for me, I will not pay 15$/L.
    Since I filled mine with M1, the trans feel more responsive and there is less gear hunt between gear change.
    As oil thin over time, it become less viscous and internal oil losses become more important, so the newer oil feel quite nice.
    In the end, the choice is yours.
    Google Mobil 1 Syntec ATF and many people use it without a problem in various cars, ranging from Chinese cars, to Landrovers to Germans...
    Feb 20 2010
    Brighton, MI
    What is that "M1"? Is it insider lingo for Mobil 1?
    05 Golf TDI
    Mar 07 2010
    Sherbrooke, Qc
    Yes, M1 stand for Mobil 1,
    more finds;
    http://forums.bimmerforums.com/forum...d.php?t=180663
    This quite conclude what I already believed!
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    For my 2001.5 A4 1.8t Quattro Tiptronic I have kinda put myself in a testing process (was planning on swapping to manual in spring time) to try out the Royal Purple ATF . So far about 2,500 miles and its shifting better, and thermal temps are down.
    Max ATF is recommended in vehicles requiring any of these automatic transmission fluids:
    * Allison: C-4, TES-295, TES-389
    * Audi G-052-025-A2
    * BMW: LA2634, LT71141
    * Chrysler: ATF+, ATF+2, ATF+3, ATF+4
    * Chrysler ATF+2 Type 7176
    * Ford: MERCON, MERCON V
    * GM 9986195
    * GM: DEXRON, DEXRON-II, DEXRON-IID, DEXRON-IIIG, DEXRON-IIIH
    * Honda ATF-Z1 (except in CVT's)
    * Hyundai: SP-II, SP-III
    * JWS 3309
    * Kia: SP-II, SP-III
    * MAN 339F
    * Mercedes Benz 236.x
    * Mitsubishi Diamond: SP-II, SP-III
    * Nissan: Matic-D, Matic-J, Matic-K
    * Subaru ATF-HP
    * Toyota: Type T, T-III, T-IV
    * Voith: 55.6335.3x (G607), H55.6336.3x (G1363)
    * Volvo: 97340 (Construction Equipment), 4-6 Speed AT
    * VW TL52162
    * ZF: TE-ML 14B, TE-ML 16L, TE-ML 17C
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Mar 07 2010
    Sherbrooke, Qc
    Quote Originally Posted by discontained View Post
    Didn't though about this one, but yes. Since my oil change, I too saw a cooler operating temperature. Then again, a more fresh/viscous fluid helped quite a bit there!
    Established Member Two Rings Spanky387's Avatar
    Nov 11 2009
    01 A4 VRT MK2 GTI Turbo
    651 minnesota
    01V Transaxle must not be in emergency running mode. Engine should be at idle in PARK. Transmission fluid temperature must be 86° to 113° F (30° to 45° C). Open the screw plug on the bottom of the trans. Level is correct if a small amount of fluid flows from the hole. Add fluid up and through the plug A. Do not dislodge filler guard cap up inside of fill hole with filling tool.
    Automatic Transmission Fluid Type Unit Fluid
    01V AE
    Automatic Transmission Fluid Total Capacity Liters Quarts
    9.0 9.5
    Automatic Transmission Fluid Capacity Unit Trans Type Liters Quarts Quantity Refers To Notes
    01V Transaxle 2.6 2.8 Initial Refill After Service C20
    C20: Capacity does not include final drive. Vehicle is not equipped W/ a TRANS dipstick, special tools and procedures are required.
