Results 1 to 11 of 11
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Stage Two Hesitation
    Under full throttle starting at around 2500 rpm, my car is sometimes spiking to around 21-22 psi. It then hesitates really bad like stuttering accompanied by slight banging noises, kinda feels like I'm hitting the fuel cut in a Honda, then brings the boost back under control and runs great all the way to red line. When it doesn't spike that high (19ish) it doesn't hesitate at all, runs perfect.
    The hesitation was once accompanied by a flashing check engine light I shut the car off and the light went out. Still off. I'll pull the codes tomorrow.
    GIAC 93 tune - and I'm running 93 gas
    Any ideas? I'm in stock setting now and the car runs great even at full throttle, any rpm.
    N75 valve?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Mar 14 2008
    San Diego
    sounds like misfires. check the codes to start.
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    Quote Originally Posted by rtl5009 View Post
    The hesitation was one accompanied by a flashing check engine light I shut the car off and the light went out. Still off. I'll pull the codes tomorrow
    N75 valve?
    similar thing happened to me when i first bought the car... hasnt happened lately though...i really dont know what caused it...try adapting your throttle position with vag com... block 60
    Jul 28 2009
    Philadelphia PA
    Cylinder 4 miss fires, sometimes cylinder 5. Looks like I'm doing plugs this weekend and moving some coil packs around.
    c8 a6 allroad
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Look for a bad (bank 2) ICM as well.
    Oct 19 2010
    Atascadero, California
    what's an ICM?
    *flame suit*
    Established Member Two Rings audiSUKKA's Avatar
    Jun 26 2009
    2001 audi s4
    San Diego ca mission
    WHen you do your plugs gap it at .024.
    Jun 26 2009
    2001 audi s4
    Quote Originally Posted by foxtrot121 View Post
    what's an ICM?
    *flame suit*
    Ignition Control module. That cause me to be on lime mod.
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    ICM - Ignition Control Module.
    Your car is hesitating because it wants you to go Stage 3.
    These are early symptoms of the turbo lady.
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by audiSUKKA View Post
    Run stock temp plugs right? The ones I have in there now are gapped to .028
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    *update*
    Plugs fixed it
    c8 a6 allroad
