Originally Posted by
MiracleWhips
Ouch, that is usually #1 on the list for a Premium setup since they sit pretty high at stock height.
Since that is out of the question, you definitely want to do an ECU tune!
Yeah, unfortunately my IS300, which is @ 3.5" min clearance scrapes the driveway every time I'm not very careful leaving it. A4 @4.2" barely passes over. But I didn't have time to do exact measurements. I might find an extra half inch for a drop, but I don't think it's worth the effort while stock springs and shocks are practically new.
Should I bother with a swaybar replacement?
I did some research on the forum about ECU upgrades. It seems there are 3 major players to choose from - APR, GIAC and STASIS. They all potentially void the warranty on engine/turbine but Stasis has a benefit for extra warranty - hence cost almost twice as much. What I couldn't find is any dyno comparisons done under the same conditions. Risking to start a holy war - what is recommended nowdays for B8?
FmL 50cmonsters
ECU tune, LED's for starters. Talk to Jens (LowestA4) about the headlights if you want them. He is absolutely the best. Best aesthetic mod there is.
I'll keep an eye for the used headlights. If the price would be too good to pass, I might find time to install them myself. Otherwise - what I dodn't see from the cockpit doesn't bother me... much.
Blake P
Aw man, if you're talking about upgrades already, might as well stretch just a bit for premium plus for a few more pennies every month.
I bought it used, so had to stick to what's was available. In any case it's almost 3 grands of difefrence between P and P+ which can be spent on ECU, light 17" wheels, extra summer tires and a LOT of bavarian beer.
