Results 1 to 19 of 19
    Dec 27 2005
    New Orleans
    OEM Battery Specs
    My battery has lasted me almost five years, so I want to replace it with the OEM and not aftermarket.
    I found two choices of batteries online but cant tell if I need the 380 amp ($150) or 450 amp one ($105). Surprisingly the 450 amp one is cheaper. I tried checking the battery under the hood, but there is nothing besides a warning sticker. My car is an 2006 a4 2.0t fwd. The dealer wants too much for it, and an arm for installation...so I will just order it online and put it in myself. So, which one is the correct one?
    Senior Member Two Rings A4s-line's Avatar
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    I believe in 450 amp came on the cold package cars but don't hold me to that.
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    why not buy stronger amp battery?
    Dec 27 2005
    New Orleans
    Quote Originally Posted by TFSI View Post
    are you referring to the 450 amp or getting something aftermarket? I was reading threads from searches I found on the forum and I concluded the best would be to get the oem. I really like that fact that his OEM battery has lasted me almost 5 years, and from past experience with other cars..I have not run into a battery that has lasted me over 3 years. That is even after I have changed out my sound system a couple times (adding amps). The only bad thing about the OEM battery is that it weights more than aftermarket batteries. What do you recommend..I have small system with 2 amplifiers too?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Just go to Pepboys. They will know what you need and will be pretty cheap.
    Dec 16 2009
    Some car
    MD
    I got the duralast with 3 year warranty, and I think it's better than oem :)
    Established Member Two Rings RightonRed's Avatar
    Aug 14 2008
    Nothern Virginia
    Always had very good luck with Optimas (Red Top and Yellow Top). Yea I know they're somewhat expensive but the last Red Top I had ran for almost 7 years (including 3 AZ/FL summers and mid-Atlantic winters) even when recharged with a POS GM electrical system (replaced the alternator twice during that time). Was also running ~1500w of stereo equipment with a 15 farad cap. Replaced the Red Top with a Yellow Top and subsequently sold the vehicle 2 years later, was still running strong. Once my OEM goes I'm headed straight back to Optima..
    Red
    Tango Red 2018 RS3 - Tech, Dynamic, RS, Driver Assistance, Black Optics
    Brilliant Red 2008 A4 2.0TQ Tip S-line KOR Turbo (sold)
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    Why don't you just go the dealer. Give them your vin and they will pull the exact battery. I think it ends with AD OR DH. Or maybe something else but it will be 380 din. Germans don't really use cca. That battery should be about 100 dollars at the dealer give or take a few bucks. Plus I am sure you can find a coupon online for the dealer for 10 percent off.
    Dec 16 2009
    Some car
    MD
    ^^he said dealer wants too much for it :)
    Sep 02 2009
    Layton/Utah
    Dealer wants too much for everything. Its a fact of life.
    Dec 27 2005
    New Orleans
    Yea they want $150 for the 380 amp (thats the one that pulled up with my vin number)..not to mention $110 for 10 minutes of labor
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    Just replaced my OEM with an Optima Red Top, did myself in 20 min. No recoding or anything besides setting the date and time. I would recommend it so far.
    Senior Member Two Rings Dubwars's Avatar
    Feb 28 2010
    06 A4 S-Line, 07 Cervelo Soloist Carbon
    St. Paul, MN
    Quote Originally Posted by apatchin View Post
    x2 This is the way to go!
    Dec 27 2005
    New Orleans
    what is the model number for the red top? and how much did you get it for?
    Jul 18 2007
    Lancaster CA
    I think I may go for pep boys since it is bosch brand. About the same price as Duralast from autozone. I tried ordering from genuine but they say they can't ship cause it's haz mat.
    Dec 27 2005
    New Orleans
    yea they just sent me the same email saying they cant ship hazardous material. Well I was about to get a red top, but from searching on this forum and other forums..the best way to go is OEM. The red top have many bad reviews online and from this thread, it seems that the OEM is better than the red top.
    Aug 14 2008
    Nothern Virginia
    Yea, just noticed on Optima's website that they DO NOT have a battery designed for VAG cars... Bummer... :(
    Red
    May 28 2008
    PDX/DEN
    Nonsense they don't list them but they work just fine. I got this one....http://www.amazon.com/Optima-Batteri.../dp/B000MS9VZK from a batteries plus store for 155.
    Most important thing is to make sure you get the 35, because the terminals are on the correct sides.
    After playing with it for a minute after installing it got it in a good location and need no additional mounts or brackets. Sits very securely in the OEM battery location.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I was hoping to only spend around $100-$120, any other suggestions here?
