Results 1 to 7 of 7
    Oct 18 2010
    Edgewater, NJ
    To-be owner of C5 A6 Avant - questions on fluid capacity
    Hello all, I am soon to become an owner of 02-04 A6 3.0 Avant.
    One of the first things I plan to do is change all the fluids in the car, and wanted to confirm the info posted by Amsoil is correct.
    http://www.amsoil.com/mygarage/vehic...A6%20QUATTRO+E
    Oil - 6.4 qts
    ATF - 10.4 qts
    Front diff - 2.8 pints
    Rear diff - 4.1 pints
    Transfer case - 2 pints
    Oil will be 5W-40, ATF is ATF, diff is 75W-90, brake is DOT4.
    Thanks for the help!
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    Depends on what size engine you have...
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by n3985 View Post
    02-04 A6 3.0 Avant.
    Feb 07 2008
    The boonies, near Seattle
    5w40? I use 0w40 synth.
    -dre
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Same here as well
    I've gone to the dark side - F25 X3
    Previous - '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Oct 18 2010
    Edgewater, NJ
    OK 0W-40 I will change, however the actual quantities are correct?
    Veteran Member Three Rings jeffp477's Avatar
    Jun 09 2009
    1982%20porsche%20924/%2005%20VW%20Touareg%20V8/2018%20VW%20Tiguan/%2717%20Triumph%20Street%20Twin/82
    temecula,ca(socal)
    probably correct for the 3.0..
    if you get the high capacity oil filter then it could be a little more.. ;)
    -jeff-
    c5union
    DIY Audi
    Audi Tech and tips
    psn:jeffp0477 gt5 whore
