Results 1 to 14 of 14
    Senior Member Two Rings Scott in H-town's Avatar
    Aug 06 2010
    Houston
    Dash rattle fix?
    So, I have a rattle that is somewhere around the MMI. It sounds like it's right behind the air vents somewhere.
    There is another around the glove box area. It's not the fuse box cover. I've checked that.
    I'm going to have the dealer try and fix. The question is, should I?
    I'm concerned that the dealer may actually make it worse. Another option may be a car stereo shop with the tools to disassemble the dash and basically do it myself with the help of a tech at the shop (and pay for his time).
    What do you guys think?
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Definitely do it before the fit and finish side of things expires.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings Voltrons_Head's Avatar
    Sep 14 2009
    Philly
    I had the same rattle. It was driving me crazy. Dealership tried to fix it but it started happening again a few days afterward. I had stuffed a tiny folded up piece of paper behind the plastic surrounding the MMI and this got rid of it for a week or so but it started again. A week or so after that. It just stopped.
    Good luck.
    Mar 02 2007
    Fresno, CA
    The rattles were driving me crazy, so I completely removed the silver MMI trim (both sides) and lined the back with felt. Now that area is silent, but now my rear passenger side C pillar is rattling!
    Aug 06 2010
    Houston
    Quote Originally Posted by NWS4Guy View Post
    When is that? 1 year 12K miles?
    Sep 14 2009
    Philly
    5K miles
    Sep 29 2009
    Quote Originally Posted by Voltrons_Head View Post
    5K miles
    Yea fit and finish is within the first 5K miles, they will address small issues like rattles and fitment of door handles, etc.
    Mar 01 2010
    BC
    So if I take it back before that, they will fix it? but I feel like it'll likely comeback like Voltron's case.. I have rattle when I'm at lower rpm
    2010 S4 6MT
    Aug 06 2010
    Houston
    Ok. I'm at 3700 miles. I've already had them 'fix' a rattle once. That one turned out to be the fuse box door on the passenger side, but they didn't address the additional rattles.
    I think if you have them address some pre-5K miles and they come back, they should still be on the hook for fixing it if it's the same rattle area. It's as if it was never repaired in the first place.
    Sep 14 2009
    Philly
    Quote Originally Posted by Un1k View Post
    You should at least try. If it comes back you won't be any worse than you are now. There's only upside in it for you.
    Mar 01 2010
    BC
    True, Thanks
    do they have to actually hear it to fix it? cuz mine comes and goes... it'll be hard to purposely make the sound so my dealership can hear it
    2010 S4 6MT
    Aug 06 2010
    Houston
    True, Thanks
    that's the worst kind because
    1) no way you can fix if you can't hear it... so yes, they need to hear it
    and
    2) If they "fix" it, how do you know it's just not on the 'goes' part of "comes and goes"?
    Senior Member Two Rings zillmc's Avatar
    Aug 22 2009
    Los Gatos, California
    Just to clarify since I've brought my car in a few times for rattles. It is 12,000miles or 1 year (whatever comes first) when warranty will no longer cover rattles.
    Present: 2013 S4 Prestige 6MT | Estoril Blue / Black Silk Nappa / SS Inlays | Sports Diff | Adaptive Suspension | Stasis ECU
    Past: 2010 S4 Prestige 6MT | Quartz Grey / Silver Black Silk Nappa Seats | Sports Diff | Drive Assist | Stasis ECU | Awe S-Flo Intake
    May 19 2010
    Cypress, Texas
    Quote Originally Posted by zillmc View Post
    I've always thought this as well. I never heard of this 5k mile thing.
