Results 1 to 7 of 7
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Help with axel situation, please.
    So I have clicking and the boot on my front drivers axel is ripped wide open. I cant see the other side (front passenger) and dont know if it is still good or not. Should I spend the extra $100 and get the passenger side too or just get the drivrs side and go from there???
    opinions please
    Senior Member Three Rings Deep6ed's Avatar
    Mar 09 2009
    NoVa
    Put it on ramps or a jack and inspect the passenger side. If it's torn, replace.
    Sometimes you can tell if there is grease all over the inside of the wheel.
    No need to replace parts if they're still good.
    2013 TT RS Plus - APR Stage 1 - Nimbus Gray - Exclusive Interior
    2013 Allroad - APR E85 Stage 1 - Scuba Blue - Sport Interior
    Oct 03 2007
    New York
    Quote Originally Posted by Everdream View Post
    But it is easier to just replace the axle (albeit it more expensive). Usually if they're torn that badly they have been compromised with dirt and will eventually fail sooner than later.
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    Just get a napa/advanced axle for the time being - $80 with a lifetime warranty I'm pretty sure. Or just rebuild your old one.
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Aug 25 2008
    rhode island
    germanautoparts has axels for $100. I wont be able to jack my car up till this weekend which I wantd to have the axels by then.
    Was just wondering if it was worth my time to order the passenger side just cause ill be replacing the drivers side. So to just replace both or not.
    Veteran Member Four Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    i would just buy two then just sell it if you dont need it. im sure somebody out there needs an axle lol
    Aug 25 2008
    rhode island
    Or just return it. good point, thanks!
