Results 1 to 6 of 6
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Is it possible erase ecu coding when removing engine ?
    **I think I might have reset my computer to stock programing (if not cleared the Unitronics file at least the coding of the ecu) The requested boost of 12psi, this code, and a strange thing the gauge cluster (prior to install the clock in the tach did not display the date, after reassembly the the date I'd visible all the time). Cats are auto speed 3"downpipes with high flow cats andno code before turbo replacement
    What do you guys think?
    VAG-COM Version: Release *311.2-N
    Control Module Part Number: 4Z7 907 551 ***
    *Component and/or Version: 2.7l V6/5VT ****G **0003
    **********Software Coding: 06712
    ***********Work Shop Code: WSC 12855
    **********Additional Info: WAUYP64B01N165836 ****AUZ7Z0A1877283
    1 Fault Found:
    16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
    *******P0431 - 35-00 - -
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Veteran Member Three Rings jsquillz22's Avatar
    Feb 22 2009
    b5 s4
    Chicago
    yes
    OEM+
    Who Cares?
    Jan 01 2006
    Boston
    any more info than yes it is possible, has any one else had this issue with Unitronics
    2014 Q5 3.0t
    Senior Member Three Rings NefMoto's Avatar
    Jul 02 2009
    Vancouver
    You can't erase the flash unless you run a tool like my free software. The ECU coding won't reset unless you run a tool like VAG-COM to reset it.
    Use VAG-COM to read the coding from your instrument cluster, and ECU, and we can tell you if it is correct.
    Also, contact Unitronics and ask them if they have put any custom code in the ECU flash that may disable the performance tune if the ECU is removed or something.
    For information on ME7 ECU tuning, free ECU flashing tools, and free tunes, check out www.nefmoto.com
    Please post in the forum before sending me PMs. I suck at replying.
    Jan 01 2006
    Boston
    That was my thought. How easy your software to use, Is it more raw code or like dsmlink with adjustable setting for tweaking files. And could I reflash over my uni file if I wanted to?
    2014 Q5 3.0t
    Jul 02 2009
    Vancouver
    Currently my software only lets you read or write to your ECU. It does not currently support editing. You can read your unitronic file, and then reflash over it, unless unitronic blocked reading.
