    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    Central locking mechanism
    Does anyone know where the central locking module is I bought a b7 key fob set and need to splice some wires on it. or does anyone have a link to a write up about installing it on a b6
    09 Prestige Package
    Sep 16 2010
    Central Wash
    Sooo.....you want to use your B7 key fobs with your B6..? And to do this you think there are some wires you need to splice? So...you're looking for a write up about installing exactly what? One of us is confused- if yo bought the right remotes then you need to
    1) Switch the key blades or have new ones cut to fit the B7 fob.
    2) Swap the RFID chips from the B6 fob to the B7 fob *or* Have them programmed, most readily by the dealer.
    3) Program the remotes with VCDS in the (46) convenience module.
    There are several threads about this only a couple pages back, ...
    B6 fob to B7 Fob
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    What he said ^^^
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Aug 11 2010
    Agawam Ma
    I think its you its not an oem b7 fob its a kit from tmtuning.com the keys are transmitted to a box with a harness with wires that have to splice on the central locking mechanism or module im not sure what its called but the chip for the immob. is in the new key and the blades are being cut tomm. morning
    09 Prestige Package
    Aug 11 2010
    Agawam Ma
    I thought it said it was a kit from tm tuning in the first post my bad
    09 Prestige Package
