Results 1 to 6 of 6
    Established Member Two Rings leoj's Avatar
    Aug 09 2010
    99 santorin a4 2.8 quattro
    British Columbia Canada
    head light issues ???
    hey i just noticed today that my driver side corner light was out , but my turn signal still works ?? the light still flashes fine when i have the turn signal on but its not on as a usual runing light like the other side so obv the bulb is still fine because it still will flash but it wont stay on when the turn signal is off ?? tryed looking thrue the fuses but they all seem good , im very confused so any imput would be great !!! thanks
    Sep 29 2010
    CA.
    simple, new bulb. Sounds like one element is burned out.
    Senior Member Two Rings frameshift18's Avatar
    Oct 15 2009
    NE, Ohio
    The side amber bulbs have two elements in them. One for turn and one for running. Same thing happened to me. You just need a new bulb.
    02 S4
    11 A4
    01.5 A4
    Jun 30 2008
    Erie, Pennsylvania
    Yep. 2 filaments. Actually they are 2 different wattages as well. Turn signal filament is much brighter than the parking lamp.
    Aug 09 2010
    sweet i wasnt expecting it to be that easy! thanks for the fast replys! btw how hard is the turn signal to get at ?
    Sep 23 2010
    1999 Suzuki TL1000R
    Pittsburgh, PA
    I just put a new bulb in mine, and the turn signal works. When I have the headlights on, the front bulb stays illuminated. Everytime I hit the brakes I have that godawful beep and if the headlights are on its every time the brake is released. Please help. Could it be a bad bulb or is there more I need to look into?
