Results 1 to 25 of 25
Thread: Wheel question
    Jan 02 2010
    PA
    Wheel question
    Will 18x8 rims with a 35mm offset fit on my stock a4 with sport suspension? also will it be ok to run 225/40-18 tires?
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    yes.
    -Andrew
    Frankenturbo/GIAC
    Veteran Member Four Rings jsantiago17's Avatar
    Aug 07 2008
    2004 A4 Quattro3.0L UltraSport
    Westchester, NY
    Yeah...you will be fine. I have 18x8 w/ et35 and running on 245/40's. I had some rubbing upfront with this size tire, but gone after a fendor roll. Stock tire size is 235/40, so you should be ok. Here's a few pics of my car to get an idea:
    |Milltek Exhaust|Unitronic Flashed|JHM Short Shifter|Koni Sports|Eibach Pros|RS4 Rear Sway|Euro RS4 Steering Wheel|RS4 Race Pedals|Miro 111's|S4 Mirrors|
    |B6 S4 Calipers|JHM 2 Piece Lightweight Rotors|Akebono Euro Ceramic Brake Pads|Evoms CAI|Hoen Xenon Match Foglights
    http://www.youtube.com/watch?v=xccmzudcY8o
    http://www.youtube.com/watch?v=BZOJIV1y0EQ
    Jan 02 2010
    PA
    Quote Originally Posted by android3000 View Post
    yes.
    Thank you! do i need conic studs? or can i just use the oem ones?
    Jan 02 2010
    PA
    Quote Originally Posted by jsantiago17 View Post
    looks good. do you have oem sport suspension?
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Quote Originally Posted by scaudi View Post
    This depends on the specific wheels, some are machined to use a ball seat bolt (OEM Style) some are machined to use a cone seat bolt (most aftermarket wheels).
    Aug 07 2008
    Westchester, NY
    Thanks. Yeah...I have an Ultrasport which is on sport suspension...
    Jan 02 2010
    PA
    Quote Originally Posted by Skyler@Achtuning View Post
    How do i check what i need? and how do i know if i need hub rings is it?
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    start by mentioning what wheels they are..
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    You can tell by looking at the wheels, and if you haven't bought the wheels yet just contact the supplier. What wheels are you looking at?
    Edit:^^beat me to it
    -Andrew
    Frankenturbo/GIAC
    Jan 02 2010
    PA
    its vsr wheels http://www.vsrwheels.com/image/wheel/victory2.jpg like these but black with chrome lip. I don't really care if you guys are going to say there cheap or what not. My dad can get them for free from work. I know how alot of you people like to be negative!
    Jan 02 2010
    PA
    no one?
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Well you will need centering rings for sure... and we can't quite see the holes good enough to give you an answer on the lugs... we would need to see the exact wheel... something like that tho I'd say I'm about 99.9% sure you would need conical.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jan 02 2010
    PA
    Quote Originally Posted by bigblue View Post
    Do i need certain rings? what do they do exactly?
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Mmmm A8 rims :)
    2010 VW GTI
    Previous cars:
    2003 A4 1.8T APR Stage 1+
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    The rings center the hub inside the middle of the wheels to keep them from wobbling/vibrating. You'll need the specs of the wheel to know if you need them or not. Try to find information regarding conical/ball/center bore of the wheels, I couldn't find any info on the website
    -Andrew
    Frankenturbo/GIAC
    Established Member Two Rings dannyace's Avatar
    Aug 27 2009
    2006 Audi A3 Sportback DSG 2.0T FSI BPY
    Baltimore
    I hope you have some big, good looking brakes behind those wheels. If not, may look a little weird. Just my thought.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Well the centering rings center the wheel as said above ^
    The wheels are universal wheels so they would have a larger bore center hole than the size of the hub on your audi... so if you can't make the wheel hubcentric (meaning centered) then it will wobble around all over the place because there will be nothing to center it as you tighten your bolts.
    Jan 02 2010
    PA
    There not universal the one i can get, they are 5x112.
    Veteran Member Three Rings zamflip's Avatar
    Sep 21 2010
    Bayliner 175, 2014 JGC wk2, and wifey s40
    Smithfield, ri
    Hey, u gotta get center hub rings and special lug nuts since i got VSR wheels set for good 2 yrs and no camber wearings...
    Jan 02 2010
    PA
    Quote Originally Posted by zamflip View Post
    How are you wheels holding up on you? what model do you have? Im just really stuck on the whole center hub rings, i dont even know what size or where to get or how you put them on, pretty sad isn't it.
    Sep 21 2010
    Smithfield, ri
    Mine-- 225/40/18, VSR # 15 i believe and as for hub rings, not sure but i bought at local performance shop in MD... i suggest u go to some euro performance shop that will order parts for you, just like i did and it was worth it
    Sep 06 2009
    Bay Area
    do you know these guys from that website? looks real sketchy, especially since their wheel selections are literally named: "wheel 1" "wheel 2" etc.
    Sep 21 2010
    Smithfield, ri
    kwarner, yeah, it sounds like sketchy but i got my rims and all perfect tho and got one rim replaced within 5 days.
    Jan 02 2010
    PA
    alright, how much were center rings, and is there a way i can mesure to see what size i need?? and whats a good place to get conic bolts at?
