Results 1 to 6 of 6
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    Strange Boost Behavior
    Yesterday, I felt the car wasn't pulling as strong, so I watched the boost gauge, and it's not reading as high, but it's not a constant decrease.
    Previously, it would hold 19 psi to about 3800 or so RPM, and then slowly decrease.
    Now, it holds 13-14 psi at 2800 RPM, and if I give it any more throttle it drops down to 8 psi.
    Any ideas what would cause this? There are no CELs.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Boost leak? I would look at your lines first. Cant remember off top of my head but there is an easy check you can do to verify this.
    edit: http://www.a4mods.com/index.php?page...tml&category=5
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Established Member Two Rings mikebo212's Avatar
    Sep 18 2010
    Burlington NJ
    Quote Originally Posted by Latin Audi View Post
    X2 same thing happened to me and this helped find the leak
    Jul 25 2008
    Marysville, WA
    Ended up just being the DV, replaced under warranty.
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    That is an excellent writeup. Having done this recently, mine uses a shrader (bike tire) valve as many people don't have actual air compressors and this way you can use the 12v ones many people do have for filling inner tubes or whatever. Because of that, I used this http://www.prestaflator.com/ to control the pressure going through a lot better.
    Pic in action
    Aug 27 2009
    Arlington, VA
    I thought I'd throw this in there because it also wasn't mentioned. Get a spray bottle, fill it with water, and then put some dish soap in it. Looking for bubbles is way easier than listening or feeling for air.
