Results 1 to 3 of 3
    Dec 03 2008
    chino ca
    B5 audi Help!?!?!
    kay so this morning when i went to let my audi a4 warm up I noticed it was leakin a bit of coolant more than a normal leak..
    so on my way to school i took it easy so all the fluid wouldnt dump and by the time got thereand cut it to let it sat in the parkin lot for bout an hour i turned it back on and the leak seem to stop..
    but this is no where the problem lies on my way back my car had a slightly meaner and deeper growl, so i ran 3rd gear no to hard but just have it a little giddy up and white smoke came through my dash vents
    would ne one know what might be the cause of this ??
    please and thank you.
    Active Member Two Rings Racerx220's Avatar
    May 05 2010
    Philadelphia , PA
    heater core?
    97 a4 1.8 , ASI intercooler hoses and turbo inlet tube , 710n dv , vdo boost gauge ,
    Jun 30 2008
    Erie, Pennsylvania
    Heater core sounds plausible. You didn't say where it was leaking from.
    Either way, we can be definite here. You should take it to a mechanic and have them pressure check the cooling system to find the leak. Then repair it as necessary.
