Results 1 to 18 of 18
    Active Member Two Rings newaudizer's Avatar
    Aug 18 2009
    Armada 2005.
    Bahrain
    Fine tune 60LB imjectors at WOT
    Hi all,, my friend has 01.5 s4 avant 6 speed with GIAC chip 93 octane only. its a stage 3 k04 but with 60LB instead of 43LB that AWE want yo to have. his question is:
    He is using lemminwinks and set the Primary Tweak to -25% but it is still giving him at WIDE OPEN TRottLe ( WOT) 9.5 AFR. hot to tune it to get it right?
    thank you
    lookin for stage 3 parts for my S4 Avant 01
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by newaudizer View Post
    thank you
    Sounds like there is a hardware problem that needs to be investigated first... Boost leak perhaps.
    Aug 18 2009
    Armada 2005.
    Bahrain
    what about if it its not a boost leak, what do you think is the problem?
    thanx
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    Get the 43lb. Duh.
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Aug 18 2009
    Armada 2005.
    Bahrain
    Quote Originally Posted by Haenszel20v View Post
    Get the 43lb. Duh.
    the plan is to use the 60lb for future upgrade..
    Oct 05 2008
    Buffalo, NY
    Then get software for 60lb.
    Aug 18 2009
    Armada 2005.
    Bahrain
    they only have ons setup and will not retune your chip to match the 60lb>>>>that really sucks.
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    The easiest, safest, and smartest thing to do would be to buy the correct injectors (43s) for the tune he is running (maybe he can find a set used in the classifieds to save some $) and keep the 60s. Once he is ready for his future upgrades he can drop in the 60s and sell the 43s used to recoup some of his money (they should sell fairly quickly as there is usually a need for stage III fueling items). He could also sell his ECU at the same time and buy a stock M-box since he's probably going to need a custom tune if he's going to need 60s.
    2002 Audi S4 Brilliant Black Avant 6MT[/b]
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    then tell him to replan for a new tune.
    Aug 18 2009
    Armada 2005.
    Bahrain
    Quote Originally Posted by BlkBullitt View Post
    I told him the same idea and he said that there must be a way to tune the 60lb. has anyone done this before running 60lb on GIAC chip?
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    There is a way... pay for a custom tune from on of the large tuners - VAST Performance, JHM, etc.
    Again the cheapest, easiest, and safest way for him to get his car running correctly is to do what I mentioned above. He can either spend a few hundred on injectors or two to three times that on a custom tune for 60s. His choice.
    Jan 29 2009
    AS said, of course there is a way to tune for larger injectors. Buy a new tune, or learn how to tune yourself and invest in some hardware and a long road ahead of you. You will not be able lemmi an existing tune for that drastic change in injector size.
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    Quote Originally Posted by NOTORIOUS VR View Post
    And even if Lemmi did work the drivability and safety of the tune would be in question. Part throttle, idle, etc fueling would likely be off which can lead to other problems as well.
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    yea get the flash out and fix it yourself, go over to nefmoto forums, we can help you out there, its rather simple to tweak injector size, but AWE has that weird maf, but i see no problem since you have a wideband
    Jan 25 2006
    A4 2.0T
    MD
    ha, i missed the part about using the wrong injectors!
    ha
    Sep 11 2009
    NE
    Injectors are rated at 3 bar. For example, 52# flow 52# at 3 bar, but 60# at 4 bar. So it is roughly 15% increase is flow for 33% increase in pressure. Going from 4 to 5 increases flow more, but I am not sure how much is it exactly.
    I don't know what FPR it is running now.... 4 or 5 bar? If 5, get OEM one which is 4 bar. If 4 bar, get 3bar. It should shave off around 15% flow for each bar of pressure drop. Combined with -25% it should land him in reasonable AFRs.
    Senior Member Three Rings NefMoto's Avatar
    Jul 02 2009
    Vancouver
    The AWE fueling kit has a weird MAF and 43LB injectors because they didn't tune the MAF scaling or injector size. They found a MAF and injector combination that gave them the ratio they wanted with the stock MAF scaling and injector size. Every other tuner scales the MAF scaling and injector size.
    Lemmiwinks can't adjust the fuel injection scale enough to go from 43LB injectors to 60LB injectors. The ECU needs to have the injector scaled changed in the flash. There is a bunch of info on my forum about how to scale your injector size.
    For information on ME7 ECU tuning, free ECU flashing tools, and free tunes, check out www.nefmoto.com
    Please post in the forum before sending me PMs. I suck at replying.
    Sep 11 2009
    NE
    You can play with FPR.
