Whats up guys? I have a 2003 Audi A4 tip Quattro. I keep having issues with Limp mode. My codes are P3087, P0172, and One for the evap not working but i cant find that one, I pulled it with an Ebay Vag-Com which I dont have access to right now. I have gone over the car several times with starter fluid, soapy water, and manual inspection. NOTHING. I did find a tear in the tip but I repaird it. I replaced the engine temp sensor (G62), bank one, sensor 2- O2 sensor, still nothing. Is there any where else i can look? Thanks in advance guys.
Update!!!
Ok I replaced the N75 valve along with the Fuel Filter and I am not getting the codes anymore = )..... At the time I posted this I started having another issue which was the 2psi prob that has also been resolved. The wastegate itself was hanging up on the wall internally so I have a new hot side coming in Muchos Gracias Slappy ( You The MAN ) Im so excited my ride should be awsome after this. Thanks guys for the input and help.
After a boost leak test I found 3 leaks; 2 at the IM and 1 at the MAP sensor. No more Limp Mode after that!!!!!!
