Results 1 to 7 of 7
Thread: Car Trouble
    Active Member Two Rings Nate_R's Avatar
    Aug 11 2010
    Camano Island, WA
    Car Trouble
    I was doin a pull in third onto the freeway and felt a kinda clunk, or stutter. My car started deccelerating and I pulled over to see what was wrong. Popped the hood and couldn't see anything weird and checked all the hoses I could see. It starts up fine but slowly starts getting worse (it starts wavering in rpm's), and won't accelerate past 1.3k rpm's. I thought it was just a vac leak but throw me any ideas you guys might have.
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Are you a 2.8 or 1.8t?
    Aug 11 2010
    Camano Island, WA
    1.8t, I went the APR route with a gt28rs so it has all those mods. If you need any more info just let me know.
    Feb 03 2009
    Philadelphia
    Could be multiple things, simple as a intercooler hose poping off, or a boost or vac leak, or N75 valve. Start with this might help you get home later so you can take it up higher than 1,300 rpms. Pull the MAF plug and the sensor before the throttle body and see if it helps. I had a similar problem happen to me but didn't want to diagnose it on the highway, but with doing that you will be able to stumble it home and check later. Hope that helps
    Aug 11 2010
    Camano Island, WA
    Thanks, I got it towed unfortunately, but I'll check it out soon. I'm really hopin it's just a vac leak cuz I think I had a small one before this happened but we'll see.
    Established Member Two Rings austinjmiller's Avatar
    Jul 12 2010
    2011 S4 Stage 2, 2001 Allroad Vast stage 3 on water/meth
    Kalispell Montana
    possibly could be a coil-pack? If a boost hose came off it usually wont run at all...
    Aug 11 2010
    Camano Island, WA
    Turned out to be the MAF so, not a huge problem thankfully.
