Results 1 to 29 of 29
    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    If there's a Audi hell...
    it's laying on your back, cold garage floor, shop light, to install a DV valve. Three bolts they say! Hour to get them out they say! Ugh... after using a short stubby allen wrench to get the bottom one off my arm felt like I'd punched my dolphin for a month strait. Middle one not so bad, used a socket wrench for that. Top one I had my wife drop the wrench between the radiator and engine to back it out while I held the bit to keep it from popping off the bolt head. Scarred hand, sore shoulder blade, and three hrs later it's upgraded and ready for APR this week. Least I saved the $, but fook. Between this and my test pipe install I hope to Christ the cam follower isn't as much a hassle.
    Still have my stock dv valve if anyone's interested in it.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    If you think a concrete floor is bad, try doing an FWD to AWD conversion on a gravel driveway!! Now THATS bad.....Lol But I do feel for you none the less!!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Senior Member Three Rings R3V3NANT's Avatar
    Apr 17 2010
    B6 A4 1.8TQ, B5.5 Passat 4M Variant,
    Dayton, OH
    I spent many a cold fall/winter evening in my driveway lying under my friend's S-10. I know your pain, but at least you knew what you're doing. Took him half a year and eventually a tow to a shop just to rebuild and install a short block.
    Jun 23 2010
    Athens, PA
    Aw man, I'm doing a DV upgrade this weekend too. Now i'm looking forward to it even less than I already was lol
    Veteran Member Three Rings porkchops!'s Avatar
    Jun 18 2008
    b7 s-line a4 2.0t quattro 6mt
    canton/new haven CT
    Boy am I glad that the previous owner already had my forge DV installed before I bought it!!
    Thumbs up for doin your own work
    If there were two guys named Hambone and Flippy, which one would you think liked dolphins more? I bet you'd say Flippy, wouldn't you?
    But you would be wrong. It's Hambone.
    FTWLTBDWICTW - don't tell your mother
    Mar 26 2007
    Colorado
    I did the DV install in 25 minutes and 2 beers. It's nice to have a second set of hands working from on top while one of you is on the garage floor
    CURRENT:
    2021 Atlas
    Jan 23 2008
    NW Indiana
    Yeah, best to go in from the top with another set of hands to help with that upper most bolt.
    Veteran Member Three Rings schizzy's Avatar
    Jun 29 2009
    2008 SRT4
    New Jersey
    Haha did the same last winter but on a paved drive way lol, always fun
    Ocean Blue b7 a4: -Revo stage II -apr/BB exhaust w/ tp -eibach/kw coil overs -19" sportec mono 10 -forge dv -rs4 swaybar -rs style grill -euro jet pcv fix -apr snub mount -custom intake -m3 spoiler -35% tints...... TOTALED BY DUMP TRUCK
    Current: 1990 vw
    Established Member Two Rings B7PhiGam's Avatar
    May 06 2009
    1940%20Ford%20Pickup%2C%201965%20Ford%20Pickup%2C%202012%20Chevy%20Silveradro%20LTZ%20Crew%20Cab
    Oregon
    I feel the pain, did mine this summer, managed to slip off and slice my knuckle on the fan shroud. Then put my mechanix gloves on.
    "I did the DV install in 25 minutes and 2 beers. It's nice to have a second set of hands working from on top while one of you is on the garage floor"
    Agreed, I think this is at least a 2 beer project.
    2006 Audi A4 Quattro 6MT - Deep Sea Blue
    ST Coilovers / RS4 Sway Bar / Forged DV / Hawk Pads /APR Stage I 91,93,100 Octane / 35% Tint / Custom Calipers
    "So wird Dich meine Liebe auf ewig umschließen"
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Isn't it amazing how beers can just amazingly help a project go by? and they are great for bartering with friends to come over and help.
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    I was fortunate enough to have my car on a lift when I installed it. Soooo much easier, seeing as though my first attempt with it on ramps failed epically.
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    I agree, beer is definitely necessary for this job - it's a PITA. I was able to get the top bolt by feel somehow. Pretty sure I was a blind man in a past life. However, after I got the damn thing off, I discovered that the previous owner had already changed it. Doh!
    The new one that I never put on is in the Canadian classifieds if anyone needs one.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Jan 23 2008
    NW Indiana
    OMG that sux ^
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    Yeah DV and HFC on an Auto are two of the most straightforward yet ANNOYING jobs I've done on a car to date...
    No longer my "DTM" S4
    Rolling STOCK B8.5 S4 for over a year and happy!
    Veteran Member Three Rings A4B7Quattro's Avatar
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    It is amazing how fast you can put stuff on a car with a friend and a case of beer lol and sometimes pizza depending on how long the job is hah
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by billyhoyle View Post
    That was the reason for my struggle during my first attempt.
    May 06 2009
    Oregon
    Quote Originally Posted by beantown View Post
    lol
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by R3V3NANT View Post
    i LOL'd when you said "just to rebuild and install a short block" as if its as easy as an oil change
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    I feel your pain man, we had about three knuckles and four extensions running off of our ratchet and were laying on a piece of plywood covered in oil from the oil change we decided to do first
    At the end of the day though, it feels much better than taking it to the shop and paying out your arse for someone else to do it
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    South Jersey
    My first attempt was a big fail after half an hour trying to get to the bolts. I got it second time in about 1hr and half, but then surprise. After a few weeks I checked my cam follower and guess what? It needed to be replaced along with the cam and HPFP (CPO here). So I took it off and put the stock one back, just to play safe. So soon I have to go through that again.
    Apr 17 2010
    Dayton, OH
    Quote Originally Posted by mr shickadance View Post
    Well, you have to figure that it shouldn't really take that long. I mean, he pointed at the fuse box and said "wow, my spark plugs are up high" and then spent a month (no exaggeration) buying and returning about 15 motor mounts because he kept looking at the wrong half of the mount and didn't know there's two parts to the mounts.
    Jul 08 2010
    tucson
    danbury
    it is a total bitch to get to that dv....my buddy who i helped put his DV in his speed3 was laughing at me when i told him what a job the DV on an a4 was....then i got to laugh at him when it took him 6 hours to put in his front sway bar (you wouldn;t believe how hard that part is to install on a speed3)
    moral of the story every car has thier problems
    Senior Member Three Rings sdy101's Avatar
    Apr 14 2010
    2010 Acura MDX Tech RES
    Central PA
    The DV is a pain, I just did mine 2 weeks ago (took me around an hour and a half)... but the nice thing is that with the right combination of tools (esp. the knuckle piece and 3" extension), there's no need to pay someone to do it. Feels great when it's done and you only had to pay for the actual part. I must have small hands, cause I didn't find the blind hole (top) all that difficult. A big thumbs up for doing it yourself!
    2013 2.0T Ice Silver Quattro, Auto, Premium Plus, Sport Pkg, B&O, Nav, Advanced Key
    H&R 15F/20R Spacers | EC Turbo IP | LED Interior Lighting | Exhaust Tips
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Quote Originally Posted by viziers View Post
    Damn...now THAT's bad!
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Oh noes
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    I have said this multiple times... you need an asian friend with tiny hands to do this job, haha. My tiny asian hand friend did it in 30 min.
    -Andrew
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by CleverA4Name View Post
    Ha ha ha, while reading this, I was like, hey, thats exactly how it was that one time I helped Trent, and it was you, haha. Fuck that sucked. I honestly would rather pay someone to do that if I had to do it again. Now the hpfp is waaaaay easier.
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by adub View Post
    Hahaha epic.
