Results 1 to 35 of 35
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Anybody with highmileage A4?
    It's been months visiting this forum particular the B6 A4 board. I come here with a question.
    I'm asking since my car hit 90k miles. What was your thoughts and decisions when you reach a certain mileage?
    Thanks
    Mac
    Senior Member Two Rings Mi1lion's Avatar
    Sep 30 2009
    Ducati 1199 Panigale ; D4 A8L
    WESTON,FL
    My B6 USP has 156K on her, I just sold it on eBay for $12,500. I just don't want to fool around with anymore and I know I'll have to rebuild the engine soon the way I drive it. Its starting the little leaks here and there, and is getting a little sluggish at times, and the rough idle sometimes in the morning. Wheel bearings are startin to grind a little, and pulling a 900LB waverunner at times doesn't help it either. Just make sure you do the timing belt/waterpump (did mine at 126k, I know I pushed it) change and coil packs, if you haven't already done so.
    shit I bought mine with 80k on it. I know a guy that has well over 300k on his A4. You just need to take care of your car!
    450whp 17psi @ 6400rpm on pump
    I am an a$$hole!
    SpecClutch.com | 034Efi.com | BoostFactory.net | QEDPower.com
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    I am at 108k. Granted I have rebuilt the engine (which only has 15k on it) but there are certain things to take care of in a timely manner regardless. Timing belt should be done every 70k regardless of mods, valve cover seals and tensioner seals tend to go at weird intervals (causing small oil leaks around the engine) and should be replaced as needed. Water pump should always be done with the timing belt, and all other routine maintenance should be followed as indicated by the owners manual. Little things like full synthetic oil changes every 5k should keep the engine running like a top. Things like wheel bearings, window regulators, etc may go...but it is hard to know at what interval. One other thing to look at is shocks, which with age will start to lose some performance. Otherwise, you should be in good shape!
    One last tip...knowing as much about the previous owner(s) and their habits as far as maintenance goes is important if possible (i.e. service logs) just so you know how the car was maintained prior to you owning it. A well maintained car will run a VERY long time...whereas cars that were not as meticulously maintained may have more issues.
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    150k + on mine and still going strong. Oil changes every 3k with a high quality synthetic, timing belt services at recommended intervals, and just being really anal retentive about EVERYTHING has helped this car stay on the road. A few bumps along the way (failed fuel pump, failed coil packs, coil pack and fuel injector harnesses, etc) but I hope to put at least another 150k on this car.
    (engine rebuild coming soon, and some front-end parts that are starting to get sloppy)
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Senior Member Three Rings R3V3NANT's Avatar
    Apr 17 2010
    B6 A4 1.8TQ, B5.5 Passat 4M Variant,
    Dayton, OH
    I have 122k, but I am the 5th or 6th owner, and the previous owners were extremely cruel to that car. For the work I put into it, I could have bought a B5 as a daily driver and garaged this one for weekends. But now she runs and drives perfectly; I couldn't be happier. (Now that I said that, something will break.)
    My dad bought a B6 3.0 with 118k a month or two earlier than I got mine and his has been mostly problem free.
    You just have to keep a schedule of maintenance and don't let things go longer than they should.
    Senior Member Two Rings yourtoys7's Avatar
    Jan 29 2009
    Buffalo,USA/ London, Canada
    139.k, runs well. Timming belt kit was done at 125k (last owner didn't think its needed that soon!) If you do basic things, it will run well.
    A4 2004 3.0L 6spd. Avant
    A4 2004 3.0L 6spd. USP Sedan/ sold.
    A4 1999.5 1.8T 5spd./ sold.
    Jan 18 2010
    13 S5 QM, 02 1.8T QM (killed by diesel 4x4), 03 1.8T QM, 84 AE 300ZX Turbo, 65 Ford Galaxie Conv
    Fort Worth, TX
    191,000 on a black on black 02 sport, 1.8t. Have a PS leak, but otherwise going strong. Can give you a list of the repairs I have done since I bought it interested.
    Jul 14 2009
    Pasadena
    122k and still running strong
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    135,xxx on mine. I had one CV Axle break, a window regulator break, and 2 CP failures. All not huge deals. Still running strong!
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Jun 08 2008
    Calgary AB Canada
    135k on mine aswell. Had some minor issues but nothing huge. BT for the last 10k with no problems but a coilpack
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    I feel like this question gets asked every 4 days. Use the search button.
    CEO and General Manager of the AZ Pedal Responce Team
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    90K is nothing, you're just breaking it in after the first timing belt swap lol. You did do that already, right?
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    187k on my '04 A4. Just moved up to a big turbo this Spring. Compression test on engine shows it's doing quite well: 180, 180, 190, 200. Had to fix some vacuum leaks, but everything is strong and solid. Simply stay on top of maintenance. I'll do the oil change every 5k miles (synthetic 5w-40 on approved Audi/VW list and large oil filter). I'll then follow Audi's schedule program for checking/inspecting/replacing everything else which is on a 10k mile interval. The timing belt/water pump/tensioner/accessory belt gets replaced every 60k-70k miles.
    USP CLUB MEMBER #34
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    High mileage - B6 forum - everyone.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by Mi1lion View Post
    Was that white color? I couldnt believe someone paid 12.5k for it with that mileage
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    Im at 130k now stock everything + cat-back exhuast. new clutch. new water pump, timing belt (almost that time again), 1 set of coilpacks. oil changes every 3k (synthetic), replaced rear coolant flange, and, oh yeah, new transmission @ 126k. got the car in July of 2008 with 80k miles. as said above just take care of it.
    however, without az, i dont think my car would be in as great of condition as it is right now.
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Oct 09 2008
    86k. Jesus you people drive alot.
    Mar 31 2004
    CA
    150356 or something around there.
    Established Member Two Rings ultrasport69022's Avatar
    Aug 01 2008
    So Cal
    Quote Originally Posted by A4OrlandoB6 View Post
    X2^^. i have almost 115k runs great!
    Senior Member Three Rings tapA4's Avatar
    Aug 25 2010
    2003 A4 1.8T FWD 5 speed
    Greenville, SC
    I've got 120k. Primarily stock, except for a FMIC and K&N filter, Podi gauge, oil change every 3k mobil1 full synthetic. Did some stuff for handling; Bilstein shocks and springs. larger sway bar. Different Snub mounts. 12 pc control arm kit.
    New clutch, slave, and flywheel resurface at 118k. Needed vacuum hoses replaced and valves right at about 116k (could've done it sooner, but oh well)
    -Theodore-
    "I swear, your mom and I are just facebook friends."
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I'm at 115K and plan to keep to 200k+
    I do plan to rebuild the motor at some point to take it to a 2.0L, but not until I'm out of law school in 1.5 years.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Sep 15 2010
    massapequa ny
    I got 296k miles on my 99.5 b5 1.8. Aeb engine original turbo. Use 0w40 since 45k miles. Got car with only 12k miles on it.
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    I had 126k on mine, never gave me a problem except for a vacuum leak
    2002 Dolphin Gray A4TQM - Totaled
    Senior Member Three Rings JeffM03's Avatar
    Dec 30 2009
    Waterbury, VT
    136k on the clock and no problems. Just like any car - take care of it and it'll last forever.
    Denim Blue 3.0L V6 Quattro Tiptronic || I jury-rig everything.
    Sep 01 2010
    Melbourne, Australia
    wow mine's done nothing compared to some of the cars here....94,000kms (58-59,000 miles) and it's a 2001 b6!
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    2003 quattr0 207k kms (122k miles give or take) barely broken in yet, runs like a champ!
    I'm just here for the free coffee
    Aug 25 2010
    Greenville, SC
    Quote Originally Posted by lookaught View Post
    Sorry to contaminate the thread lol. I'm about to get out of high school and head to law school...what law school are you studying at?
    -Theodore-
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    117k and running strong. I've felt with the normal B6 problems.
    Veteran Member Three Rings hbodo08's Avatar
    Apr 06 2009
    04' a4 3.0 ** 02' envoy slt--85' iroc z 28 (7400 original miles) 2010 Mercedes e350 4 matic
    The ville, Ohio Akron, Ohio
    mine has 104,000 on it and i bought it 2 years ago with 78,000 im going to do my timing belt soon and all the other maintenance.. i change my oil every 5k and use 5w-30 or 40 but i like using castrol edge... and change all my fluids when i have the time to do it my cars running great
    I drive it like i stole it , then again
    /____________________\
    [_oo_\===0000===/_oo_]
    \_o___[HMB-30A4Q]___o_/
    Jun 21 2005
    Milton, Ontario
    145,000 kilometres.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Nov 23 2006
    Soooouuullllll Cal!
    WOAH! Did not know every A4 owners have highmileage! You guys kick ass!
    Screw it, I'm going to keep this car!
    2003 A4 1.8TQM
    Markham, Ontario
    214,000kms.
    GIAC 1+, Stasis Streetsports, B7 A4 front brake conversion, Adam's rotors / Hawk HPS at all corners.
    Timing belt x2, both front wheel bearings, wiper module, driver's side xenon system (everything but the bulb, including some wiring) new clutch and differential output bearing replacement (not one of the regular items :( )
    As others have said, stay on top of the maintainance and you're good.
    Veteran Member Three Rings Gooner1886's Avatar
    Jul 20 2009
    Indiana
    Wait, your still around here?
    why?
