Results 1 to 16 of 16
    Sep 03 2010
    Okemos/MI
    NEED HELP BIG TIME (recommendations of any kind would be nice)
    Well... I bought a 1999 Audi A4 b5 2.8 quattro (manual trans) without doing any research in the performance area and now I don't know what to do with it. (Yes I'm a bit of a "noob" at the whole audi tuning thing.) Apparently there are no performance upgrades that will out right give me horsepower so maybe a combination of performance upgrades will give me a good enough amount of horsepower? Getting to the point, I need decent performance combinations and the brands that will help me get there. Any suggestions? Anything would help me at this point...
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    PES Supercharger.. Other than that.. Exhuast, Intake, And nitrous..
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    X2 PES Supercharger
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 22 2009
    new zealand
    all you can really do for more than about an extra 20hp is go to a supercharger. or sell it and buy a 1.8t
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    But make sure you have a 30 valve 2.8 v6 because i believe they don't make superchargers for the 12 valves. Right?
    Apr 22 2009
    new zealand
    Isnt the 1999 well into the 30V models? i thought the change was in like 96 -97 or something? might be wrong though
    Feb 03 2009
    Philadelphia
    Maybe i am mistaken between the just the face lift on B5's between pre 99 and after 99.5? I thought maybe the the 30 valves came in 99.5
    Jun 30 2008
    Erie, Pennsylvania
    30v was introduced for the 1998 model year in the US market.
    As far as mods, make it sound good and handle good. That's the best you'll do without a supercharger.
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Your really that dissapointed with the 30v's performance? I think it has more than enough power.
    But short if a supercharger, you won't find any mods that give you power.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Slowly transform it into an S4 then S4 Swap and the rest is already there
    Sep 29 2010
    CA.
    Quote Originally Posted by Dedude View Post
    The people before me give good advice. Here is an excerpt from the "audizine wiki" for b5...
    "...Modifications-US Version:
    Available for the 2.8L is CAI (Cold Air Induction), exhaust systems, ECU chip and suspension upgrades. Another option is super charging of the engine. One reputable super charger manufacturer to go with would be PES, which comes in the form of a the G1 kit (no longer produced) which the blower was side mounted on the right side of the engine or the G2 kit (30V only), which is mounted atop the engine. Another manufacturer is Motodyne. They produce a kit for the 12v V6 with a twin screw blower that sits atop the engine similar to the PES G2 kit. Also available for the 2.8 V6 are ported throttle bodies, ported intake manifolds, large bore MAFs, adjustable FPRs, clutches, headers, MSD ignition modules and nitrous oxide kits. There are several older versions of the 12v V6 (one being AAH) that were used in the previous chassis. The cylinder heads on these engines have larger ports, better camshaft profiles and double valve springs that can be used on the AFC engine to produce more power of standard AFC equipment......"
    http://www.audizine.com/wiki/index.php?title=B5_A4
    Established Member Two Rings mbudden's Avatar
    Sep 16 2008
    Colorado
    Quote Originally Posted by FNK View Post
    Why not just buy a S4?
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    buy an S4 engine, build the lower end, gather parts for the top end of the 2.8 motor. talk to the guys at EPL about what they've been doing. you'll have yourself a streetable monster.
    as far as keeping the same motor, PES supercharger, meth injection and fmic. you can build the motor if you want to run a smaller SC pulley.
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Sep 03 2010
    Okemos/MI
    Wow thank you all for the advice. I looked at the PES G1 and G2 superchargers and they are just way too expensive (3k+). I also think it would be cheaper to sell it and buy an s4 instead as opposed to converting the a4 into an s4. All things cconsidered i'm thinking maybe i should just try to trade it for a 1.8T.
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    honestly dude, if you want something decent to MOD , then sell it and get into a 1.8t. WITHOUT a doubt, if you ever want to go crazy, you can.
    Garage: b5 s4 silver stg3 f21s
    RIP Daz 4/14/16. Legend.
    Oct 06 2004
    Minnesota
    Quote Originally Posted by DonnieDark0 View Post
    Best bet ^
    This topic has been literally beaten to death.
    Closed. Search the forums please.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
