Results 1 to 21 of 21
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Replaced battery and starter, car still won't start... any ideas?
    Hey everyone,
    Been having an issue with my car abruptly not starting anymore. Full power with key on at accy, solenoids can be heard clicking. Once everything goes silent I try to start the car, silence. So I proceeded to replace the starter, successfully did that and no change to symptoms. no changes have been done to my car recently. just parked it at home over night and next morning no go. I have replaced the battery for giggles with no change.
    Thanks everyone.
    What symptoms show bad ignition switch?
    Lurker
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Clutch peddle switch can go bad. Same thing Happened to me once, replaced the switch and it started right up.
    Any codes?
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    no codes.
    it's a tip. only 2 peddles
    Lurker
    Senior Member Two Rings TozoM8's Avatar
    Sep 17 2010
    Black on black 01 Twin Turbo S8, 6MT, built in SRX 01' allroad 2.7T
    Chicago
    Try it in N.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    nothing. same problem
    Lurker
    Sep 17 2010
    Chicago
    Apply 12V to the little wire that goes to the starter. If it cranks then you have the problem upstream. If it doesn't then check the ground cable to the motor, make sure you have 12V at the big wire/cable on the starter. If your starter has two small terminals for the small wire, make sure that your small wire is connected to the top terminal that is closer to the motor.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    yeah, i plan on testing the starter i pulled out first, to see if that was even a problem to begin with
    Lurker
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    replaced ignition switch... still broken.
    jumped excitor wire and car tried to start. now what
    Lurker
    Senior Member Three Rings supremedk's Avatar
    Dec 14 2009
    B8 SQ5
    Gilbert AZ
    You need to find out why the signal isnt getting from your ignition switch to the starter. Possible break in the wire someplace, i am not familiar with the auto trans in our S4's, but there has to be some sort of lock out switch that will not let the car start unless its in Park or neutral, i would check a wiring diagram for one and start there.
    Jun 21 2004
    mpls, mn
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    I would suggest replacing everything before diagnosing it.
    EPL Stage 3 with a bunch of other crap.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    youz a smartie.
    still have access to that wiring schematics i need to see excitor wire from firewall to key path
    Lurker
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Quote Originally Posted by jprice View Post
    FTW!
    My vote is to buy some more parts.
    Jun 28 2005
    2001 S4 Avant
    Steamboat Springs, CO
    LMAO
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    found starter wire runs to a brown plug with violet tabs under ECU. continuity from firewall plug to here is solid.
    have also found starter wire has juice post ignition key with multimeter. there's a break somewhere in between the starter wire section directly under steering column to the harness connection in the ecu box.
    any takers? i've tried to follow the wire path, but it disappears near the cluster
    Lurker
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    i wonder if the car ever had an alarm or starter kill in it at one time. The wires from the ignition switch run over the column, then down over to the fuse box. You should pull your culster out and the harness coming off the ignition is right there, see if it has previously tampered with. If they used a crappy connector you might be getting an intermitent connection.
    Mar 04 2008
    '11 S4
    MN
    Quote Originally Posted by infinkc View Post
    Hey peter don't you have a fancy smancy alarm for the TIP of yours?
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    un-related... i've tested or positive current after the remote start/alarm in line the starter wire
    Lurker
    Established Member Two Rings vagra4nt's Avatar
    Aug 09 2005
    b5 s4 01.5m, vw 02 1.8t gti
    LI, NY
    it's repeated post like this that make me think it's only a matter of time before my number is picked. If you are running a s4 as daily driver with no backup you either have big balls, are too cheap to get a 2nd car as backup or both.
    If i see one more post like this I'm reregistering my 2.slow
    Dec 06 2007
    Calgary, AB, Canada
    Take a length of wire, and attach one end to the starter reference wire, and the other to the positive 12V on the battery. If the car starts, you know that the ref wire is your problem. If so, check for power at that wire at the fuse box, then you'll know if the problem is pre, or post-fuse box. The more you can narrow down the problem area, the better.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    already narrowed it down... ran a line... called it done.
    Lurker
