Results 1 to 2 of 2
    Established Member Two Rings AJ88CAB's Avatar
    Oct 04 2006
    Atlanta, GA
    Rear Inner CV Leak question
    See (slightly hazy) pic.
    I noticed both rear inner CVs are leaking. The leak is between the metal cap and the CV joint. It is a clear oil but it must be from the CV joint grease. It is definitely not differential oil, and there would be no way for diff oil to get there. The bolts are tight.
    Anyone see this before? Does it require taking the CV joint apart or can I seal it with bead of sealant. I am working on the rear suspension so "stuff" is off, but I'd rather not pull the drive shafts and rebuild the CVs. But I imagine eventually it will cause problems if not addessed.
    thanks - Andrew
    aj88cab
    Marietta, GA
    2002 Audi S4, Silver, 6 Speed
    1988 Porsche 911 Cab
    1972 Porsche 914 (long term...really long term...restoration project)
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    CV grease is not light colored unless lithium grease is used. And in that case it wouldnt drip or have the same consistency as gear lube. You most likely have 2 leaky rear diff seals. they are easy as hell to fix. just buy two new seals and install them.
