Results 1 to 7 of 7
    Active Member Two Rings Big W's Avatar
    May 22 2010
    10 A4 2.0T
    Montreal
    Transmission kicking
    You guys are the only ones who can answer this. A couple months after ownership or 5000 Km on the odo, the engine and transmission needed to be changed due to vibrations, they didn't know where the vibrations came from but AOC suggested to change the transmission, since that didn't fix the problem they proceeded to change the engine which had fixed the vibrations. Since then, occassionally when getting to a full stop downshifting from 2nd to 1st kicks bad, I brought it back since they claimed they had to adapt the transmission to the engine, that reduced it a bit but it still does kick and it's really embarrasing when you have passengers, reminds me of my 1988 Bonneville, anyone has the same experience?
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    that sometimes happens to me, only after i have floored it maybe lol or got off the highway
    2010 A4 quattro, Tiptronic, Ibis White
    Registered Member One Ring timwoj's Avatar
    May 06 2010
    Queen Creek, AZ
    Mine's been doing the 2nd->1st kick since I got it new. Only 2k miles on it, so it's going to have to go in to get checked. Overall, I find the downshifting to be really clunky so far.
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    It does that .. the gear drops from 2 to 1 right before you hit the dead stop.
    Veteran Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    same goes for me, I've had two transmission issues so far. First was the hard shift from 2nd to 1st when coming to a stop. Second was that I had to use the paddle shift to get out of 2nd as the car was holding the gear WAY too long. The dealer did a transmission software update and the hard shift from 2nd to 1st was still present (fixed the other issue though). Unfortunately, you might just have to live with it.
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by timwoj View Post
    Just hit 50K, still does that. It is what it is.
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    May 22 2010
    10 A4 2.0T
    Montreal
    The Question is, are we ok with that?
