Results 1 to 19 of 19
    Jun 22 2004
    palm desert, CA
    prevent amber corner bulbs coming on with headlights?
    Hi I just purchased a 2000 audi a4 1.8TQM. When I turn on the headlights the amber corner turn signal bulbs stay on as well. Is this normal. If so is there a way to prevent this? thanks guys
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    http://www.socals4.com/diy.html
    Pretty easy, just follow the DIY
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Jun 22 2004
    palm desert, CA
    thanks!!
    Sep 06 2008
    Bellingham, WA
    No problem.
    -Matt-
    Aug 13 2008
    Indiana
    Just remember it's technically illegall for your ambers to be off with your headlights
    Jun 22 2004
    palm desert, CA
    really? I didnt know that
    Jun 30 2008
    Erie, Pennsylvania
    Yep. That is your corner marker light. It helps other drivers to see the corner of your car. Headlights are often not on the corner, they can be recessed into the body, flip up style, etc. So the corner light is important. Your car will fail a safety inspection (or they will sell you 2 new bulbs and charge you for the install) and you may be pulled over for it. There are very specific rules for these sorts of things. For LED tails, for instance, there is a minimum percentage of the LED's that must work to pass. Also, the fender turn signals must work if they are present. You can disable them, but the lens must be removed. If the signal is behind the mirror glass, it can just be disabled as there is no visible lens.
    This is for PA, but I imagine other states have similar laws.
    Veteran Member Three Rings teleTay's Avatar
    Jul 19 2010
    2000 A4 Avant, 2004 S4 Avant
    SLC UT
    somewhat related question. i recently did clear corners on my one piece headlights and i considered either buying or painting my bulbs silver and having them still blink amber. however i left the amber bulb for the time being at least. is it a law to have the actual bulb be amber or is it only required to blink amber?
    *painting didnt seem like a great idea to me because of the fact that the paint might melt if the bulbs got to hot?
    Established Member Two Rings alsabti3's Avatar
    Aug 19 2010
    ann arbor - MI
    Quote Originally Posted by teleTay View Post
    ^ What I did to solve this is buy a set of "replacement" turn signal bulbs from a local hardware store. They are clear bulbs that flash a standard yellowish color. Although it is not as amber as the OEM bulbs, they can still be distinguished from the actual lights, or so that is the case with me. try em out, theyre like 3 bucks, if you feel it is not "legal enough" just paint the bulbs with spray paint. ...
    '00 A4 1.8fwd.auto
    Established Member Two Rings chodemaster's Avatar
    Jun 09 2010
    Flawiduh
    yes it will melt
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    All the people running e-codes are illegal... How do they get away with them?
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    How are e-codes illegal? I would suggest that you not hand out false information...
    As long as you have working headlights that have an amber turn signal/marker light it is legal...
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by 2001A4QUATTRO View Post
    Well, on my e-codes marker lights are not on when headlights are, so per walky_talky20 statement it makes my headlights illegal
    Established Member Two Rings mbudden's Avatar
    Sep 16 2008
    Colorado
    taken from ECS Tuning:
    Driving at night is only as safe as the distance you can see in front of the car. More light projected further down the road where you need it is exactly the advantage a European “DIP” beam offers over the dated North American beam pattern.
    European headlights offer a drastic improvement in beam pattern and brightness of the headlight. They reflect a much crisper defined beam of light down on the road, even without increased bulb wattage.
    For off road use only in select areas, please check your local laws.
    Those apply to Jetta e-codes but I do believe they apply to B5's as well. US headlights are approved headlights from D.O.T while the e-codes are not. If a cop wanted to be really anal, could actually bust you for not having proper headlights.
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Quote Originally Posted by BASARAB View Post
    What does how you wired the car/what bulb you used have to do with being legal? I was intelligent enough to modify the housings to use my factory corner marker bulbs and sockets... GL :)
    May 28 2008
    2015 Tacoma Off Road
    He also stated to check your states law as it could vary from state to state. If your state requires orange corner bulbs that come on when your headlamps are on (CO does) then yes, they are illegal.
    2015 Tacoma Off Road - current
    2001.5 S4 avant - sold
    2001 A4 sedan - hit and totalled
    Aug 13 2008
    Indiana
    They are supposed to be on. I have OEM Valeo E-codes and mine act exactly like stock headlights.
    Technically we are supposed to have orange markers on the sides of the headlights but clear corners have enough of a loop hole to get around with out being hassled.
    -Nic
    Jun 30 2008
    Erie, Pennsylvania
    Yeah. Truly they are supposed to have some amber "reflection", even with the car parked. The reflection is so other cars can see which end of the car is which at night, even if it's parked. Red in the back, amber in the front. Europe must not have this stipulation, which is why the US B5's got those little orange plastic thingies in the headlight housing and the E-codes are just nice looking.
    There is actually measurements for how much light must be reflected back, which is why heavily tinted lamp housings are illegal, even when the bulbs shine through. The tint cuts down on the reflection factor twice as much because the light passes through it twice.
    Mar 01 2010
    Farmington Hills,Mi
    My e-codes are set to rest of the world, maybe thats why. I will try with US and Canadian mode. And in MI u can run pretty much anything u want, no emission or any other kind of check up at all.
