Results 1 to 40 of 49
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Opinion on Sound System
    Ok, I was just curious what kind of sound systems people are running, I always hear that the stock Bose sucks because when you apply and aftermarket head unit the Bose speakers output is drastically reduced, but then again I have a couple friends with infiniti's and nissans with the Bose system and they put in a new amp, sub, and head unit and they love their systems never replaced the 2 front or 2 backs. So why when I contact local audio shops or bestbuy they tell me I have to replace all the speakers or else my system will suck with the Bose.... What are common setups that people use I don't want to drop a stack on a system, maybe just head unit, amp, and sub or maybe even just amp and sub and keep stock look. What does everyone recommend? Thanks in advance.
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    My car had some crazy setup when I bought it. Not sure what he did to make it all work. Doesn't matter though. I improved it by ripping it all out and selling it.
    Sound systems are heavy.
    Stock bose has great sound just not the loudest.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Bose system is good enough if u add one extra amplified sub. But if u think of replacing speakers, u gotta rewire and get all new system. There are a lot threads about it if u search
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Quote Originally Posted by BASARAB View Post
    Yeah, I know about rewiring, but what do you recommend about keep stock head unit with an amplified sub.
    Mar 01 2010
    Farmington Hills,Mi
    Aftermarket no doubt is better, but many people choose to keep stock headunit for clean OEM look. No need to change it unless u want navigation,bluetooth and all that fancy stuff. Just add a bit more powerful amp
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Bose amp is designed for the 2ohm speakers, so changing the speakers can create issues unless you either bypass the amp, replace it with an aftermarket amp, or stick to 2 ohm speakers of the stock size & ratings.
    The deck can be replaced no problem, but the bose amp is the weak link of the system. The Bose amp is what splits the audio signals to the speakers & controls the crossovers.
    Because of this any aftermarket deck will sound pretty much the same as the oem radio did unless you bypass/upgrade the bose amp too.
    You dont need to spend a ton, pick up a deck & speakers, and bypass the amp. You will get a great sounding system, and you can always add an amp later on. Wont limit you to 2ohm speakers either, you can pick any setup you want. (so long as it can physically fit)
    00 Hibiscus S4 Tip
    Mostly Stock...... for now
    Oct 05 2010
    York PA
    BOSE= BUY OTHER SOUND EQUIPMENT
    no highs and no lows- must be bose
    rip em out- replace front components (5 1/4 will fit with some persuasion)and some coaxials in the rear deck- no need for the 6 inch mid bass in the rear doors- cut their wiring and leave them dead
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by WikiWiki View Post
    I thought the rear doors were 3.5"
    Jan 29 2007
    08 S4 00 S4
    MD
    Before you replace anything, you should try playing with the EQ settings for the factory system. No need to change any components and it adds a better dynamic to the factory system that might meet your needs on a budget.
    08 S4- Stock SOLD
    Senior Member Three Rings ColinGruenfeld's Avatar
    Oct 24 2006
    Stage III Tiptronic B5 S4
    Colorado
    Quote Originally Posted by mholme View Post
    Absolutely true. The stock EQ sucks. Search it, there's a thread about how to tweak the "Hidden Equalizer". Night and day difference.
    Audacity - The Nogaro 2000 S4
    STAGE 3 PJ K04's + IPT Tranny/TC + This and that
    Full Stage III TIPTRONIC
    Senior Member Three Rings Tormented's Avatar
    Sep 12 2010
    2007 Mazda 6
    Texas
    Those stores tell you that you have to replace those speakers because they want to make more money, its as simple as that. Thats just how stereo stores work.
    Senior Member Two Rings Short4Law's Avatar
    May 25 2009
    Florida
    If you wanna keep it simple swap your speakers out for infinity reference, they are 2ohms. Change your head unit, add a x1 amp and a 10" sub.
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by Short4Law View Post
    Is the price for one speaker like $180?
    May 25 2009
    Florida
    About 180 for a set.
    Veteran Member Four Rings LowA4's Avatar
    Aug 04 2007
    00 S4, 01 Allroad
    Gardnerville, Nv.
    I added a 1000 watt amp and 2 10's to my stock bose and it sounds amazing. Crystal clear with good bass now.
    C5 RS6
    Stage 3 b5 S4
    8P A3 quattro
    B6 usp A4
    C5 Allroad
    Mar 01 2010
    Farmington Hills,Mi
    Jun 24 2009
    ABQ NM
    5.25" components in the front doors, you need a separate tweeter & woofer.
    6.5" Coax in the rear doors, oem does not have a tweeter.
    6.5" subwoofers in the rear deck lid (back window), and are dedicated mini subwoofers.
    00 Hibiscus S4 Tip
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I'm actually quite happy with my Bose system connected to my Carputer giving the signal.
    I did add a single 12" sub though, the bass sucked on the stock system.
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Wow, a little surprised to hear such negative opinions on the stock system. I run a Dice iPod adapter and the stock sound and I'm very pleased with it. I don't need tons of bass, perhaps I'm just a little too old for such a thing. I like the bass and clarity of the BOSE system. Could it be better? of course, but cost/benefit wise, I'd rather just stick with what I have now.
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Thanks for opinions all, I think I am going to try and do some research on the "Hidden Equalizer" and see what that gives me and maybe just add a single 10" or 12" sub/amp and keep stock bose, I think thats staying safe.
    PS
    Does anyone have a 10" and wish they had a 12" in this forum? Or is anyone satisfied with their 10"? Just curious I have never heard a subbed S4.
    Oct 24 2006
    Colorado
    Quote Originally Posted by blackjak View Post
    PS
    I've gone through the following systems with my S....
    Factory BOSE + 1x 12"
    Factory BOSE + 2x 10"
    Factory BOSE + 2x 8"
    Infinity Speakers + 2x 8"
    Depending on your choice of music, I would say stick to 2x 10's for a universally acceptable flavor of bass. 2x8"s provide good quality and clarity, but little bump. I kind of miss the 10's.... I was never a fan of the 12" though... shook the crap out of everything and was too low on the bass scale. Each to their own, just my two cents.
    Jan 29 2009
    Quote Originally Posted by ColinGruenfeld View Post
    Agreed, even one proper 10" in a good dialed in box is better then a 12 for most types of music.
    Veteran Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    What size are the front speakers, actually?
    Bose = blose. But out of many of the stock bose systems I've heard, ours isn't the worst. If you replace the head unit and speakers simultaneously, you'll want to get 4 ohm speakers and skip the infinity's.
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue DxC/BritishTurbo Stage GTX
    GTX2863 Build Thread - 575WHP
    Sep 12 2010
    2007 Mazda 6
    Texas
    Replace everything, get good component speakers all around and get 1 good woofer, either 10" or 12" and i promise you will leave with a smile on your face. Hifonics make extremely good component speaker sets, go with a kenwood head unit if you plan to add a subwoofer because they run 4v to the preouts vs 2v from majority of other stereo companies. More V to the pre outs the better quality bass you recieve. Also for the amp go with a rockford fosgate because their amps are extremely under rated as far as power goes. I built a system in a scion toaster (forgot the model of the thing) with a single 300W 2 channel Rockford Fosgate amp that powered 4 15" Rockford Fosgate T2's . That alone should speak for itself
    Jun 24 2009
    ABQ NM
    Quote Originally Posted by Tormented View Post
    Just because you did it doesnt mean it was a good idea, considering the t2 is rated for 1000w rms each.
    Quote Originally Posted by shorterthanrich View Post
    OEM the front Bose speakers are a 3 bolt 4" woofer & a small 1" tweeter.
    You will never find a replacement 3bolt 4", and dont need to since a 5.25" will fit pretty easily.
    Hidden EQ isnt that hidden.
    Turn the radio off, press & hold preset #5 while turning the deck back on.
    A series of 8 numbers will pop up
    First # = Fronts low bass
    Second #= Fronts mid bass
    Third # = Fronts mid treble
    Fourth # = Fronts high treble
    Fifth # = Rears low bass
    Sixth #= Rears mid bass
    Seventh # = Rears mid treble
    Eighth # = Rears high treble
    Volume knob adjusts the number, P.scan button moves to the next number. Numbers go from 1 to 9, 1 being the lowest 9 being the highest, factory preset is 55555555.
    Turn the deck off then on again for the new eq to take effect. Rinse & repeat as needed. lol
    Bose system is poor at best, but as you have seen in here everyone has their own tastes & desires for sound quality. Personally, I feel the Bose system has muddy & quiet highs, moderate midbass, and a low end that is great at mid to low volume. I am far from a bass head, and found a single 10" with 400~500w easily overpowered the entire system.
    00 Hibiscus S4 Tip
    May 25 2009
    Florida
    Quote Originally Posted by Dutchsider View Post
    That dice works with the bose?
    Sep 12 2010
    2007 Mazda 6
    Texas
    [QUOTE=Audiophyle;5795808]Just because you did it doesnt mean it was a good idea, considering the t2 is rated for 1000w rms each.
    Also doesnt mean it was a bad idea either. i was simply stating that Rockford Fosgate amps are extremely under rated. And that amp handled those woofers just fine. And seing as we built the car for Rockford Fosgate im pretty sure they were aware of the capabilities of their equipment. So yes i think it was a good idea because it was for marketing to show what could be done with their products. But i dont know what im talking about or anything
    Feb 07 2008
    The boonies, near Seattle
    Yeah, actually it does.
    Certainly doesn't sound like you do....
    -dre
    Sep 12 2010
    2007 Mazda 6
    Texas
    How are you going to say it is a bad idea? Please explain. Seing as that amp is what RF wanted us to use with those subs i dont see what the problem is. Maybe you guys should be the owners of RF instead.
    Oct 02 2009
    Sydney, Australia
    I've just swapped out my 1DIN stock concert(?) headunit for a 2DIN kenwood touchscreen running to a 6ch Signat amp running the stock bose speakers with focal tweeters & crossovers to supplement the high end in the front & have a 12" MTX thunder 9500 installed(but not running yet).
    Even though it was a thrown together system from extra audio gear I had lying around you would be amazed what the stock speakers can sound like when you give them some real power, they have some awesome clarity once powered right. Probably best not to push them too far but they do produce adequate volume.
    I thought about putting some of my AVI speakers in but wasn't convinced I needed to after hearing the BOSE powered by a proper amp. I'll just keep them ready in case I blow the Bose up.
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    +1 on the Focal stuff. That is what I will be putting in my front stage soon. Maybe even mod the rear deck to hold some 7" Focal mid bass for some real bump.
    Junior Member One Ring blazns4's Avatar
    Oct 19 2010
    bergen county nj
    i have my stock bose speakers and stock amp running just fine on my s4 w my subs and aftrmarket dubble din- stock bose system is really one of the best on the market i do alot of systems and thats your best best
    Sep 12 2010
    2007 Mazda 6
    Texas
    blazn where did you find your double din dash kit?
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by blazns4 View Post
    I had Infinity fold system in my old 2000 Grand Cherokee, even without subwoofer it sounded way better than my current Bose. So I went ahead and bought Basslink and Reference speakers, hopefully it will improve my system lol
    Aug 30 2007
    nyc
    I beleive bose are a paper cone... a synthetic cone is better than paper..... infinity mkes awesome speakers but any major components set speaker plus tweeter should be awesome.. kenwood, pioneer, jbl etc.....
    c5 A6 tip
    this n that
    Veteran Member Three Rings ski&drive's Avatar
    Feb 22 2010
    00 S4
    Metrowest Boston
    I think the bose is a great system for what i use it for all tho i never really listen to it.
    Buy a twin 1 and some dp's and you wont want to listen to the bose
    Jun 24 2009
    ABQ NM
    Who at Fosgate asked you to do it? A tech or a salesman? My guess is the setup was a marketing ploy to sell these amps & boost hype because the general public is stupid.
    You were running 4 1000w rms subs on roughly 300w each. (1/3 rated power on a power hungry sub) While it is impossible to underpower a sub, it is VERY easy to push such a setup into severe clipping, which WILL destroy even a 1kw sub. Did you set the gain with an O-scope or DMM? How do you know what kind of power it was actually pushing if you didnt? (easy, ya dont)
    For a "show car" its one thing, but to use such a setup to claim RF is superior is something else.
    The amount of wasted money to get 4 T2 15's when a smaller & far better matched sub could have easily kept up (if not sound better), but would not have lived up to the over-hyped car audio world.
    Maybe its just me, but I prefer to get the most for my money, which doesnt include buying high price subs & running them off an amp made to run door speakers.
    Fosgate is a great company but far from what they were 10+ years ago, and never will be again.
    Quote Originally Posted by Monaro-Azz View Post
    This I completely believe, because I think the Bose amp is the primary limiting factor to the oem system.
    Give the speakers more clean power (adding tweeters was also a good idea) and using an amp that doesnt do stupid things to the signal, and you should be golden. Speaker placement, orientation, and install is quite a bit better in the Audi than many other cars (the main focus of Bose to begin with). Bose uses decent quality speakers, but have seriously lacking amps.
    00 Hibiscus S4 Tip
    Aug 19 2010
    NEPA
    Yes sir, charges and functions with the head unit controls.
    Mar 01 2010
    Farmington Hills,Mi
    Quick question about installation. I installed Basslink (self amplified sub) and used similar to this hi-lo converter
    I connected red wire and yellow together and connected them to my positive right rear speaker wire, green and white to negative right rear speaker wire.
    Now I have a question, is my set up gonna be allright or should I go the proper way and connect each wire to both right and left rear speakers wires?
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    So some people have successfully added an aftermarket amp to the Bose system, so I'm assuming if you wanted to add a sub you need another amp on top of that? I though the Bose only worked on 2 ohms or does that not matter with amps and only headunits I like the idea of adding an amp to the Bose system but would you place it where the old amp is, I don't even know where that is, lol. Does the Bose sound substantially better anymore base or rather just loudness.
    I've got lots of questions!!
