So, car has had a bad misfire issue since I bought it. Ive been starting to diagnose the problem and also contacted EPL about it since they are the ones that did the stage 3 install. Misfires are mostly on cylinder two, about 40 per minute, though there are also misfires on cylinder 4, 3, and 6. I moved spark plugs and switched coil packs and it did nothing. EPL said it is definitely an injector problem as they have replaced the seimens injectors that my car has with bosch in their kit due to idle misfire issues, though the PO said it didnt misfire for a while after the install so I have my doubts. However, tonight while replacing the coolant level sensor plug, I unplugged the MAF to see what would happen. Low and behold, misfire issue completely gone....while the clutch is depressed. Clutch up in neutral and the misfire returns, though not NEARLY as bad as when the MAF was plugged in. The car is also having an overboost issue as it is leveling off at around 26 psi but im contributing that to a bad passenger wastegate line. Any ideas what the problem could be? This is kind of a weird one.
