Results 1 to 17 of 17
    Active Member Two Rings Billan's Avatar
    Oct 11 2010
    Audi B7 S4 DTM - BMW 318TI (winter beater)
    Western, MA
    2007 S4 - Right Rear Rubbing
    So I am new to Audi's and I can't figure this out. I am currently running VMR 19 inch RS4 like wheels with 245-35-19 tires on vogtland coilovers. The car currently sits 25 inches fender to ground at each corner. I am rubbing on the right rear only. If I do the "finger" test I have plenty of clearance on the left side but not the right side. I have re-measured etc and they are the exact same height to ground. Does the S4 have some weird offset on the right side causing this? I am going to raise the car up again to at least 26 to stop this but I can't explain why it's happening.
    Thanks for the help!
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    25.5" should be plenty, but then again, most people are running 235's not 245's.
    I actually have kinda the same issue and not explanation. While you're raising it up though I'd check to ensure all the bolts are tight to ensure there isn't extra play as I had to retighten my bottom shock bolt as it had loosened over time.
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    Senior Member Two Rings dannslc's Avatar
    Dec 05 2006
    Dubai
    I have the exact same issue on the right side only. I think its quite f'in strange. My front and back right rubs first all the time, even with just me in the car. You would think It would be the opposite.
    Oct 11 2010
    Western, MA
    It's very weird. What size 235's are you running? 235-40 or 235-35?
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    alignment.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Oct 11 2010
    Western, MA
    Just got an alignment done with no difference. Do you have any specs for what the rear should be? I have my alignment read out.
    B7 S4 DTM - RS4 front brakes - Vogtland GT coilovers - Corsa exhaust - Hotchkis RS sways - Strat SS - Strat CAI - VMR 19" wheels
    Sep 16 2008
    Quote Originally Posted by Billan View Post
    no, because i requested a certain spec.. -2.1 degrees. it could have come lose if it wasn't tightened properly.. i really think it's alignment .. mine were way out, too, before i got mine done recently. one side rubbed.
    PREVIOUS:
    Sep 13 2008
    Western Chicago Burbs
    what is it rubbing on? the wheel liner or the fender itself. are your fenders rolled?
    IMO your main problem is running 245 wide tires. most people go with 235's. Also 25" is pretty damn low.
    Oct 11 2010
    Western, MA
    I am rubbing on the fender liner. I am raising the car up now and will see if that helps. If not I will drop down to a 235 tire. It's just weird that it only rubs on the right side. If it was the tire width you would think that the left side would rub also. I am still investigating a potential alignment issue as stated above.
    Senior Member Two Rings MikeS4's Avatar
    Feb 14 2008
    searching for something new
    Savannah
    check the bolts on your sway bars. i had one of mine come out completely (LR) and didnt notice it until i was raising my coils to try and combat the rub. it was the sway bolt all along.
    hope it helps
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    I roll on 245s, and I get rubbing sometimes in the right rear. I am on stock suspension, so I would assume that you would get more rubbing in the rear. Going 235s would be your best bet. Wonder why it was just the right rear...
    BTW, is that a sprint blue DTM S4 that you have?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Oct 11 2010
    Western, MA
    channad - yes, I have a sprint blue DTM (I see we have the same taste). More pics in this post (http://www.audizine.com/forum/showth...al-repair-shop)
    For the guys running 235's on 19's are you running a 235-35-19 or a 235-40-19?
    So I looked at my rear alignment specs and the right side is -1.8 and the left is -1.7 degrees. Staticuxo I bet this is why I am rubbing and your not at -2.1.
    Sep 16 2008
    well, i chose to run -2.1 for extra clearance .. plus i'm running 225/35/19 on 19x9 et29. my fender liner was literally sitting on the tire before i added some camber lol
    PREVIOUS:
    Jan 24 2008
    West Coast
    235/35/19's on mine. 19X8.5 Hartmanns.
    Moderator
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    I have the same problem with the same setup. I'm not sure exactly what my heights are around the car but I really only get it when I have heavy bags in the boot. Gonna check the heights again when I put the winter tires on next weekend, but otherwise it doesn't bother me too much.
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Dec 05 2006
    So. Cal.
    If you really wanted to, you could adjust your subframe to sit a little further to the left.
    Oct 11 2010
    Western, MA
    Quote Originally Posted by MattboyR32 View Post
    Do you run 245's or 235 on your VMR's? I rub over large bumps with nothing else in the car. If I put people in the back it's game over, rubs way to much.
