Results 1 to 2 of 2
    Nov 23 2009
    Help On Replacing Air Filter
    I tried searching for any tutorials on replacing an air filter for a B8 A4 2.0T so if there is one, please direct me there and my apologies for opening an old topic.
    I'm not car savvy by any means, but I'm slowly working my way there and I was replacing my air filter with the proper K&N model, but came across an issue when I had to remove the final two bolts to get the housing off. The two bolts are blocked off by a hose, so I essentially need to figure out how to get the hose off. I removed the metal clamp on the hose, but still can't get it loose and I don't want to pull to hard as I have been known to break things by doing just that.
    Any suggestions, and especially pictures would be of great service.
    Established Member Two Rings lagouardedupouy's Avatar
    Jun 25 2010
    France
    to disconnect the hose from the turbo I had to pull very hard.
    to disconnect the hose from the air box and retrieve the original part that plugs into the stock air sensor, I had to ask a friend to hold this part and I had to draw by turning from right to left.
    Audi A6 C6 V6 3.0T (november 2008)
