Results 1 to 10 of 10
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Transmission gone - water in it
    After taking the transmission out of the 1996 A4 2.8 Quattro auto, it was opened for inspection by my local trans shop.
    The fluid was milk coffee brown. They said water had gotten into it, likely by a leak of the trans line running through the radiator.
    Likely, it will be cost prohibitive to rebuilt the trans.
    I haven't checked, but I thought the car has a separate air to fluid transmission cooler? Or are the 2 coolant line from the trans indeed running through the engine radiator (and a leak could force coolant/water into the trans circuit)? If so, I need a new radiator, too. Right?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    yup the factory transmission cooler is the radiator. if something happens then you get water in the transmission fluid. You can prevent that by installing an aftermarket air to air cooler for the transmission
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Feb 20 2010
    Brighton, MI
    So I could:
    a) get a new radiator (combination engine/trans)
    b) keep the old radiator (with assumed internal leak to trans cooling lines), plug connections for trans lines, and use just for engine cooling; get aftermarket transmission cooler and install.
    What size for the external (or sources/links)?
    Where and how to mount it on my A4?
    05 Golf TDI
    Dodge RAM 1500
    Pittsburgh Area
    Here is what I would do. If you are going to replace the transmission then I would get a new radiator, and do an external transmission cooler. Any size from Summit, or jegs, Or ECS if they sell them. the reason I wouldn't keep the old rad would because if its bad then you would be loosing coolant.
    Feb 20 2010
    Brighton, MI
    New radiator and new trans cooler. Wow ($$$).
    Where to mount the external trans cooler?
    the radiator already has to deal with the condenser for the A/C.
    Are there pics of examples out there where external trans coolers are installed?
    05 Golf TDI
    Jun 22 2009
    Dundalk, MD
    do a manual swap. Easier and cheaper
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by [email protected]. View Post
    Well, for this particular car, it is designated for my daughter and therefore needs to remain an auto trans.
    The transmission swap seems to be rather complicated (see http://www.audis4parts.com/page23.html).
    So, selecting a project Audi is best done by selecting the desired transmission. Can the engines be swapped more easily?
    Id Est:
    A4 B5 2.8 V6 quattro manual swap to 1.8T?
    A6 manual swap to 2.7T?
    Regarding the auto trans I have.
    Its a ZF-5HP-19FL
    I was surprised to find that this trans is also used in much stronger cars:
    BMW 97-current, 3 series E46, 5 series E39, 7 Series E38
    Audi 95-current, A4, A8
    Audi 97-current, A6
    Porsche Boxster 96-97
    VW Passat 96-Current
    So: how much can the trans in the A4 2.8l quattro handle with respect to power/torque?
    Does the above mean I could source a trans from the cars mentioned and install in in a 1996 Audi A4 quattro? I would assume (strongly) that this is not possible, considering the quattro (at the very least).
    05 Golf TDI
    Dodge RAM 1500
    Pittsburgh Area
    Quote Originally Posted by vtraudt View Post
    Id Est:
    Its a ZF-5HP-19FL
    Audi 97-current, A6
    the tq rating is only 310 Nm.
    the external trans cooler could just be mounted in front of he condenser.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by blacka4 View Post
    No concern regarding air flow? trans cooler, condenser, radiator on top of each other?
    05 Golf TDI
    Dodge RAM 1500
    Pittsburgh Area
    Nope I wouldn't see a problem with air flow. you could mount it someplace else, like where the side mount IC would be on the passenger side
