Results 1 to 19 of 19
    Active Member Two Rings NYRS4's Avatar
    Aug 23 2010
    Brooklyn
    Arrow Rear Brake Upgrade question? JHM B6 rotors/ with 034 adapter brackets
    First of all sorry if this has been asked before, did some searching and didn't find my answer,
    I know JHM sells the rear BBK kit for $785 which uses a 325mm rotor (12.8") heres the question can you use the
    b6 s4 rear rotor which is 300mm (11.8") $500 with the 034 brackets ($75) plus the SS lines ($50) which gives us $625 and a total savings of $160, or should I just fork over the extra 160 and shut up and stop annoying ever one with noob questions? If any one has any other suggestions please let me know, I do not plan on tracking my car just want some good stopping power, and just to make sure the front b6s4 rotors fit to the b5s4 front? thats what I gathered anyways.
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    For that money, go with the Stasis rear kit with 2pc rear rotor
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    The JHM rotors are bigger, but also 2 piece/custom rotors which presumably makes the price difference. In short though, yes, you could just source the B6/B7 S4 rotors yourself and do the rest. BTW, check out 034 as they may have a "rear bbk kit" too.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    The B6 rears are the cheapest and the easiest rear upgrade for our cars. Just get the 034 brackets and you're good to go and it is a true upgrade if you are on a budget if not then go for the JHM BBK.
    OE Set of rear B6 rotors are like $120 pair or you get a nice set of slotted or something for under $200 pair easily, not $500. So it's much cheaper to do the B6 rears. The links below should give you an idea of what you will spend for the B6 rear rotors.
    OE set, http://www.partsgeek.com/catalog/200...ake_rotor.html
    Slotted stuff, http://www.ecstuning.com/Audi-B6_S4-...king/OEM/Rear/
    Mar 18 2009
    brooklyn, ny
    Quote Originally Posted by sqitis View Post
    +1. get 034 bracket. OEM B6 rotors and some lines. u r done.
    ps: i presume u already upgraded front brakes? if u r still on stock fronts - do not do this.
    Jan 03 2010
    Gloucester Ontario
    Anyone figure out a pad solution to eliminate the inner 1/4 inch of the b6/7 s4 rear rotor that doesnt get touched by the stock pad?
    Aug 23 2010
    Brooklyn
    OH SORRY TO ALL !!!! what I was talking about was JHM B6S4 rear rotors thats why I stated $525, not just Oem ones, sorry should have been more clear, I was typing that at like 3:30 at night so wasn't really thinking straight, any other inputs for a good rear kit.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    I used 034 brackets, DBA B6/B7 rotors, hawk pads, and 034 rear lines.
    I would prefer to custom make a set of lines so if u want my 034 ones PM me
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    What's wrong with the 034 lines? Could you just use some G-stop lines?
    By the way, I would also go with DBA B6/7 rotors in the rear with the bracket to re-fit the caliper.
    Buy my B5 S4 Body panels!
    The dollar bill is nature's suicide note
    Sep 11 2007
    Tampa, FL
    Nothing wrong with them, they aren't as long as I would like them tho. You can not use goodridge lines or anything else. Its either 034 or custom because you need a banjo bolt to instal the line to the caliper because a typical line threads into caliper and with the 034 brackets the rear upright gets in the way of doing that.
    Aug 23 2010
    Brooklyn
    Any reason why to go with Dba instead of JHM rotors?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Quote Originally Posted by NYRS4 View Post
    The DBAs are less expensive. Still very nice rotors though. But the JHM rotors are lighter.
    -Darrick
    Sep 11 2007
    Tampa, FL
    the only reason to go with JHM IMO is because they are lighter. DBA IMO is a very good rotor. It has a good track record. But then again if you really want to spend money you can buy 2 piece DBA, but they still arent as light as JHM. I didnt care. I dont like buying rotors or brake products from someone that just fabs up brakes. Thats stupid in my opinion. Brakes need to come from a trusted company.
    Aug 23 2010
    Brooklyn
    hey thanks for all the input guys where would I be without the vast know how of the forum.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Why not just get B6 s4 rear calipers, they bolt up. bigger pad surface area + 300mm rotors.
    l gotta-- l gotta get
    a form from a scientist.
    Aug 23 2010
    Brooklyn
    Quote Originally Posted by Sleeeper X View Post
    you can do that I didn't know this they bolt right up ??? with no brackets or anything would you loose the parking brake with this set up, can you point me in the right direction.
    Sep 11 2007
    Tampa, FL
    yup. you loose parking brake
    Senior Member Two Rings titikaka's Avatar
    Dec 25 2009
    S4 00' , A2 Sport 03'
    Bulgaria
    Quote Originally Posted by *Blue-Angel* View Post
    what ..with B6 rears?
    Sep 03 2010
    Nashville, IN
    Even with the bigger rear brakes the system is still a 80/20 pulse system right? So only 20% of breaking power goes to the rear no matter what size rotors you have. I can see the bigger caliper and pad surface helping for sure with a bigger rotor.
