Thread: wrong pcv
    Established Member Two Rings TitanTeamRoper's Avatar
    Dec 14 2008
    05.5 2.0 Frontrak
    BigBearLake=SoCal
    wrong pcv
    I went to the dealer and picked up a new PVC andI got the wrong one I got the one that ends in L for 05 and early 06's. But I have a late model 06 which is supposition to have the one that ends with E. Will running the other one going to mess anything up, or should I get the correct one?
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    not speaking from experience, but go for the correct one, just sounds like common sense to me.
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    If you truely have the wrong one your car will run rough and you will immediately know and will want to get the right one.
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    Will not run right. Not sure how bad it is to go that direction, but I accidentally was sent the new one in the past and the car would not idle.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Dec 14 2008
    05.5 2.0 Frontrak
    BigBearLake=SoCal
    My car running great, my mpg have gone up a lot. The only difference I can find is the way one of the hose connects the one I took off has an s curve then shoots straight back and this one just shoots straight back. The way the internals work is the same way.
